Toilet Hole - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2010, 09:09 AM   #1
toilet hole
I removed and existing toilet during renovations , my question is if I don't put some kind of seal on it will the water thats in the drain back up thru the hole.
steamfittergirl is offline   Reply With Quote
Old 08-17-2010, 09:15 AM   #2
Yes, it can. But it will back up somewhere else too if its not draining correctly. My big worry would be construction debris falling down the hole and getting stuck. You can get a 3" or 4" test cap at the hardware store (usually has a wing nut on it) that will seal it completely, or just stuff a rag in the hole to keep stuff from falling in
the_man is offline   Reply With Quote
Old 08-17-2010, 09:19 AM   #3
Owner
LateralConcepts's Avatar
Yes, you should cover it during a renovation. But if there's water standing in the flange you have a blockage.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-17-2010, 09:25 AM   #4
toilet hole
We had the line cleaned out and our septic cleaned a couple of months ago. The problem started when we moved our kitchen accross the room. I can run the dishwasher no problem i can flush the upstairs toilet no problem but when i take a shower the water comes up. does that make sense.. mind you the showere is up stairs and the open hole is down stairs. I'm thinking I need a permanent seal until I can have the toilet installed?
Old 08-17-2010, 09:28 AM   #5
toilet hole
The water does drain in the flange. so I know it's going out.
Old 08-17-2010, 09:48 AM   #6
Owner
Water still shouldn't come up regardless of where you run water. I'm still having a problem picturing why you get water when you run the shower upstairs, but not when you flush the toilet upstairs.
Perhaps it has already come up a bit then drained by the time you get back down there? (which would mean small blockage). Maybe watch while someone else flushes the toilet. You may also have a fitting in backwards where the shower ties into the main near the downstairs toilet.
When you do eventually reset the toilet, the water will gurgle in the toilet when you're running the shower if the problem isn't remedied.
Lateral
(208) 818-8241
Toilet leaking from seat mounting hole jrpoole59 Plumbing 11 05-05-2010 11:25 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
What to cover the toilet drain hole with while doing renovations? RyanD Plumbing 4 06-15-2009 07:05 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet hole Q - not to the sewer Jumper55 Plumbing 1 10-21-2006 11:07 PM
