Toilet Hissing Noise When Flushed? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-15-2010, 06:56 AM   #1
toilet hissing noise when flushed?
my toilet makes a strange hissing noise whenever I flush it,can someone tell what i have to do to fix this problem
ckr31 is offline   Reply With Quote
Old 12-15-2010, 08:25 AM   #2
To make a wild guess, it is probably your "fill valve". That is the thing in the toilet that lets the water into the tank and then shuts it off after reaching the right level. A new fill valve is not that difficult to install. I like the fluidmaster 400a.
broox is offline   Reply With Quote
Old 12-15-2010, 10:29 AM   #3
Ok thanks I will try that and see if that's it
Old 12-15-2010, 11:13 AM   #4
I agree. If you remove the tank lid and flush, you will probably see water being shot out from where it shouldn't be. The Fluidmaster 400A is under $10 and has great, easy to understand installation instructions.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-16-2010, 06:34 AM   #5
I guess if two people say the exact same thing I have beleave both of you
Thanks so much I love this board
Dripping noise from toilet drain redpoint5 Plumbing 18 10-30-2013 06:23 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Toilet Leaks When Flushed - How to get at closet bend!! OldHouseNewProblem Plumbing 3 12-11-2008 06:24 AM
weird pipe noise after toilet flush bourbonboy Plumbing 1 11-30-2007 04:18 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
