Toilet Guts Need Replaced - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2009, 08:34 PM   #1
toilet guts need replaced
hello all, i need a fast answer so i know what to expect when i go to home depot tomorrow
my toilet tank is leaking and i thought it was the line going from the shut off valve to the tank, so i replaced it. its still leaking but its leaking at the water inlet. there is a black gasket that is there that i have removed and it is like dripping black ink from it. is it ink, i doubt it but it looks like it, once it gets on my hands its hard to wash off.
to make a long story short do i need to replace just the black rubber gasket or do i have to replace the whole toilet part that has the float attached to it?
what am i looking at for cost?
reds_21 is offline   Reply With Quote
Old 02-02-2009, 08:46 PM   #2
If you can find a matching gasket do that. If not you can buy the inlet piece (without ball attachment) and replace it and connect it to the ball... another option is to buy the new kind that requires no ball. That would set you back 10-15 bucks max.
scotty123 is offline   Reply With Quote
Old 02-02-2009, 08:51 PM   #3
thank you scotty123!! 15 bucks i can handle. i mean if i have to replace an old part, i might as well replace all of it for that price. i was expecting more than $15
Old 02-03-2009, 01:51 AM   #4
Rewards Points: 2,906
If the flush valve is reddish brown or light grey with a black top and float, then it's probably a FluidMaster. If you contact FluidMaster, they'll send you one free. I have FluidMaster ballcocks in all my toilets, and they sent me 10 of those gaskets free.
If it's not a FluidMaster, I'd check the "Master Plumber" section of Home Depot and see if you can buy that black gasket just by itself. You should be able to.
http://www.fluidmaster.com/html/troubleshooting.html
If it's not a FluidMaster, then buy a new FluidMaster fill valve and replace the old one in your toilet. FluidMaster is widely regarded to be the best fill valve design on the market, so most people would recommend you replace what you have with a FluidMaster..
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-03-2009, 08:00 AM   #5
Rewards Points: 26
Red, go agead and replace the whole fill valve. Here is the whole kit for the toilets from lowes for 19 bucks http://www.lowes.com/lowes/lkn?actio...P30&lpage=none
Or here is just the fill valve for 7 bucks http://www.lowes.com/lowes/lkn?actio...P75&lpage=none
I like to replace all the parts so I don't have to worry about anything else going wrong. If you just replace the fill valve, couple months down the road the flush part might go bad and then you have to dig back into the toilet again. For 20 bucks and another 30 minutes I just do the whole toilet. Good Luck
ponch37300 is offline   Reply With Quote
Old 02-03-2009, 08:57 AM   #6
Rewards Points: 1,548
Originally Posted by reds_21 View Post
there is a black gasket that is there that i have removed and it is like dripping black ink from it. is it ink, i doubt it but it looks like it, once it gets on my hands its hard to wash off. ?
Ashes to ashes, dust to dust.
The gasket may have biodegraded. Many plastics have petroleum products as some of their ingredients. Some such plastics biodgrade into a sticky oily goo. Chlorine in water can hasten the process.
I have also encountered plastic toilet parts, notably the fill valve, becoming brittle. Thus the advice to replace the whole fill valve assembly, not just the gasket.
Another OT: I have encountered (my house) steel bolts holding the tank to the bowl. Fortunately I caught it (noticing a slow drip) before a bolt rusted through completely, dropped out, and allowing a not-too small trickle that would unleash hundreds of gallons if it happened while I was away at work.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 12:57 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 05:03 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
