Changed WC1 over the weekend. Now we have a pretty good gurgle at WC1 when WC2 is flushed. Apparently the the trap and water level is lower on the new toilet, so less pressure to hold back the thrust of air when the WC2 is flushed.
pic 1 is the current layout, pic 2 is what I am considering. Any thoughts?
You can't use any fixtures not on the same floor as your wet vent on any fixtures that is called a stack. You also cannot tie anything within 30 inches of the base of a stack.
The bottom picture needs a vent on the tub. And from the stack 90 horizontal you cannot tie in the tub within that 30 inch zone. Also make real sure your using an air admittance valve not a cheater vent with a spring.
I did change the layout to pic 2 with exception to the tub which is tied in ahead of the of wet vent 90. The current pic shows it behind the 90. It is more than 30".
Yes, I am sure that is what's on there. I will change it.
But don't think that is going to help with the gurgle.
We ran a test, by removing the 1 1/2" clean out plug. When flushing WC2,
the water in WC1 was nearly still. Think I need to tie in another vent.
But what ticks me is the old toilet had no issues.
Then install the AAv on the tub 4 inches above the tub trap and vent the lav to air. One of the two must go to air to release your positive pressure that developed. An AAV will not do this.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
