Toilet Gasket Mixing? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2012, 05:06 PM   #1
Rewards Points: 91
Toilet gasket mixing?
I have an eljer and am replacing the tank to bowl gasket and bolts. apparently the gasket is the type with ears. http://www.plumbingsupply.com/images...95-5702-00.jpg
wondering however if I can use another type since i already have it. it's this kind.
http://www.homedepot.com/Fluidmaster...1#.UIHOrG-HIrV
no_Wedge is offline   Reply With Quote
Old 10-19-2012, 05:42 PM   #2
Rewards Points: 13,752
Those ears are to help set the bowl level and to also avoid over tighting the bolts.
Just be carefull and tighten the nuts equaly and it should work.
Old 10-19-2012, 11:02 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I've run across some toilets, mostly Kohler, that take a specific close couple gasket for the tank to bowl connection. The port on the bowl being just slightly larger than a korky or fluidmaster gasket. I'm not saying what you have won't work on your Eljer, but just be aware....
JDC is offline   Reply With Quote
Old 10-20-2012, 05:30 PM   #4
Rewards Points: 91
guess i'd just better get one since they have them at the local lowes
Old 10-20-2012, 08:26 PM   #5
Rewards Points: 582
I would do just that...that sponge gasket would be to big for the eljer...ben sr
Do I keep tightening toilet tank to compress gasket? Tank is not touching bowl sethpnc Plumbing 6 04-24-2011 02:54 PM
Should gasket overlap spud washer on toilet? boarderx Plumbing 19 01-03-2011 11:40 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 02:40 PM
