-   -   Toilet gasket mixing? (http://www.diychatroom.com/f7/toilet-gasket-mixing-160582/)
no_Wedge 10-19-2012 06:06 PM
I have an eljer and am replacing the tank to bowl gasket and bolts. apparently the gasket is the type with ears. http://www.plumbingsupply.com/images...95-5702-00.jpg
wondering however if I can use another type since i already have it. it's this kind.
http://www.homedepot.com/Fluidmaster...1#.UIHOrG-HIrV
joecaption 10-19-2012 06:42 PM
Those ears are to help set the bowl level and to also avoid over tighting the bolts.
Just be carefull and tighten the nuts equaly and it should work.
JDC 10-20-2012 12:02 AM
I've run across some toilets, mostly Kohler, that take a specific close couple gasket for the tank to bowl connection. The port on the bowl being just slightly larger than a korky or fluidmaster gasket. I'm not saying what you have won't work on your Eljer, but just be aware....
no_Wedge 10-20-2012 06:30 PM
guess i'd just better get one since they have them at the local lowes
ben's plumbing 10-20-2012 09:26 PM
I would do just that...that sponge gasket would be to big for the eljer...ben sr
