Toilet Flushing Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2008, 02:12 PM   #1
toilet flushing problem
Hi,
Ok, so i have no idea whatsoever about plumbing and im hoping someone can give me an idea of whats wrong and will understand what im trying to explain.
When i flush the toilet the cistern takes an age to fill back up again, so the toilet wont flush for about 5- 10 mins after. If i take the lid off i can see the water trickling out, it doesnt have the traditional ball-cock
Sorry if this makes no sense but i dont have a clue!!!
jules81 is offline   Reply With Quote
Old 06-01-2008, 04:34 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yea, install a new fill valve, get a fluidmaster 400A, see pictures on box, simple as 1 2 3.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-01-2008, 08:43 PM   #3
Fluidmaster always works good for me too. If you have an old ball and float fill valve try turning the angle stop off at the base of the toilet.
There should be 4 screws on the top of your fill valve inside the tank, take those off, then put a rag over the fill valve and turn the water on for a few seconds. That should blow some debris out of the valve. Put it all back together and check it.
That usually works for me in houses on wells or with bad water.
Good luck!
KGPLUMBER is offline   Reply With Quote
Old 06-02-2008, 01:00 PM   #4
Good luck!
There doesnt seem to be a way to get into anything! There's definately no screws.
Old 06-02-2008, 01:06 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
jules,
As Ron said, just replace the tank water inlet valve with a Fluidmaster 400A float-cup type. They only cost $5-$7 bucks and come with very easy illustrated installation instructions. To me, it's even easier than trying to "repair" or blow-out an old one.
Mike
Mike Swearingen is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 10:33 PM
Toilet Flushing ? Piney Plumbing 5 10-20-2007 01:56 PM
toilet bowl water level problem? darsunt Plumbing 3 08-26-2007 01:10 AM
toilet vent problem? docholaday Plumbing 8 06-21-2007 05:05 PM
