Toilet Flushing Causes Noisy Cold Water Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2010, 10:08 AM   #1
I have two toilets in two separate bathrooms. When I flush either of them the cold water pipes, especially in the basement, make a loud banging noise when the the toilet tanks are refilling. I can run cold water from any of the faucets in the house with only a slight noise problem. I assume that the main cold water pipe running to either batroom is common to both the toilet and the sink. Any suggestions as to the noise problem would be appreciated. Thanks.
mrduck10 is offline   Reply With Quote
Old 02-02-2010, 08:56 PM   #2
Sounds like water hammer. They have devices called "water hammer arrestors" that might help. You might be able to get away with turning down the flow in to toliet for a temporary fix as well. Less flow going through the pipe should result in less of a hammer affect when the valve closes suddenly.
Wiseman067 is offline   Reply With Quote
Old 02-02-2010, 09:02 PM   #3
Military Mom of 4
Snav's Avatar
Yeah - water hammer studs are nice, get some . . . installation is minimal.
Some indepth info:
http://www.plumbingsupply.com/waterhammerarresters.html
After installing that, if it doesn't cure the entire problem, then I'd run along the pipelines and replace supports - water hammer is exaggerated when the pipe aren't secured and they have more room to clack around.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-03-2010, 06:10 AM   #4
Thanks for your comment. I'll give it a try on anything I can get at.
Hot water starts hot but gets cold quickly. CenterShock HVAC 31 12-26-2009 05:06 AM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 04:01 PM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 11:00 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
