Toilet Flushes Twice - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2014, 09:11 AM   #1
Rewards Points: 41
All of the sudden my toilet began flushing twice per flush. I just replaced the flapper just before this started. I tried replacing the lever arm that pulls the flapper - no luck. I tried adjusting the fill level to a lower setting - no luck. The flapper isn't going down in time. It's almost as if the flapper isn't heavy enough. Anyone ever had this issue? I did a search on here and couldn't find any related topics. Any help would be appreciated.
Thanks!
slappydan is offline   Reply With Quote
Old 04-24-2014, 09:19 AM   #2
Rewards Points: 320
Try a different setting on the chain. Maybe just needs tweaking a little.
jmon is offline   Reply With Quote
Old 04-24-2014, 09:26 AM   #3
landfillwizard's Avatar
Rewards Points: 516
What type of flapper did you use? The flapper may not be set close enough to the seat (inside the toilet) to close.
landfillwizard is offline   Reply With Quote
Old 04-24-2014, 09:29 AM   #4
Rewards Points: 41
I tried both lengthening and shortening the chain - still no luck. I even put a fishing weight on the flapper to help close it faster. That didn't work either.
Old 04-24-2014, 09:30 AM   #5
Rewards Points: 41
I just got one of the black universal flappers. The one that came out was red. I might pick up a different one today just to rule it out.
The Following User Says Thank You to slappydan For This Useful Post:
jmon (04-24-2014)
Old 04-24-2014, 10:46 AM   #6
joed's Avatar
Rewards Points: 13,368
Lower the water level in the tank.
The Following User Says Thank You to joed For This Useful Post:
Bob Sanders (04-27-2014)
Old 04-24-2014, 11:16 AM   #7
Rewards Points: 1,716
Disconnect the chain from the arm and flush by manually lifting on the chain and let gravity do its thing. If that works the flush lever is binding.
Old 04-24-2014, 11:20 AM   #8
Rewards Points: 44
You need a water saving flapper. Fluidmaster has one that you can dial up or down to change the flush duration.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
jmon (04-24-2014)
Old 04-24-2014, 01:14 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 996
Better to have it flush twice you removed the 1.5 and replaced it with a 3.0 i myself have all my toilet dumping more water when possible i always get rid of the 1.5 and replace them with the old 3.0 especially if you have older cast iron pipes. 70 percent of the main or branch line clogs we get are a direct result of poor flushing toilets.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following 3 Users Say Thank You to Javiles For This Useful Post:
jmon (04-24-2014), MTN REMODEL LLC (04-24-2014), SHR Plumber (04-24-2014)
Old 04-24-2014, 04:33 PM   #10
Rewards Points: 582
you installed the wrong flapper.....
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
SHR Plumber (04-24-2014), TheEplumber (04-24-2014)
Old 04-25-2014, 12:39 AM   #11
Rewards Points: 41
After much troubleshooting, I've determined that it is not the flapper. When I stop the water level at the halfway point and flush, it only flushes once. The water level setting is at it's lowest point. I need a shorter cutoff mechanism (not sure what it's called).
Old 04-25-2014, 12:40 AM   #12
Rewards Points: 41
I'm still baffled as to why this started happening out of the blue.
Old 04-25-2014, 08:12 AM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 996
Its not flushing twice because there isn't enough water to flush twice,
Old 04-25-2014, 08:36 AM   #14
Rewards Points: 41
Any idea why it IS flushing twice?
Old 04-25-2014, 09:08 AM   #15
Rewards Points: 44
Wrong flapper. If you have another similar toilet at home, flush it and hold the handle down so the flapper stays up. You should get the same double flush.
Dan
toilet flushes slowly pcoates Plumbing 2 01-19-2012 09:13 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
New construction, toilet flushes strange. premipet Plumbing 7 02-08-2008 09:30 PM
Toilet flushes slowly, but no visible clogs... poorboye Plumbing 4 09-13-2007 11:02 AM
