Toilet Flushes Slowly - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2012, 12:14 AM   #1
toilet flushes slowly
Have a toilet in one of the bathrooms that flushes slowly. The water empties fine from the tank but then does a weak swirl in the bowl and takes several flushes to clear the bowl of anything. I plunged and did use an auger. When I plunged, the water wouldn't rush out but after a handful of plunges, the water would be mostly out of the bowl. With the auger, it seemed at times I would hit a solid blockage and other times it would go right through. Wasn't sure if maybe i was just getting stuck in a tube or if I was actually hitting an object. With the auger all of the way in, the toilet flushes fine, but once it is pulled out, the toilet goes back to not flushing properly. Toilet doesn't overflow at all.
pcoates is offline   Reply With Quote
Old 01-18-2012, 08:17 PM   #2
Rewards Points: 582
something is stuck at the bottom of the opening,, the auger moves it out of the way to flush then when auger is removed object moves back..I would ..pull toilet inspect trap ..
Old 01-19-2012, 09:13 AM   #3
MarginallyQualified
Rewards Points: 2,464
do you have young kids in the house? the sort with plastic bath toys?
Toilet Flushes Different ImDoingIt Plumbing 2 02-19-2011 10:27 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
New construction, toilet flushes strange. premipet Plumbing 7 02-08-2008 09:30 PM
Toilet flushes slowly, but no visible clogs... poorboye Plumbing 4 09-13-2007 11:02 AM
