Toilet Flushes Different - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2011, 10:37 AM   #1
Hello,
When i flush my toilet, the water goes out of the toilet, but then it goes silent (doesn't fill back up) for a minute or two. I can hear the water moving through the pipes right after the flush. Then after a minute or two, the toilet kicks on and starts filling the bowl again. Also, sometimes I get a sewer smell in my bathroom.
This is an upstairs toilet.
Any help would be greatly appreciated.
Thank you!!
ImDoingIt is offline   Reply With Quote
Old 02-19-2011, 11:24 AM   #2
Lightfoot's Avatar
Rewards Points: 272
if it's a Fluidmaster fill valve, it sounds like the rubber valve seal needs replacing. Only a couple of bucks at lowes/HD or any hardware store. Takes about five minutes, and instructions are on the back of the package. Sewer smell is likely a different problem.
Lightfoot is offline   Reply With Quote
Old 02-19-2011, 11:27 AM   #3
check and see if the float in the tank is stuck against anything. i see a lot of wc's like that where the ballcock is jammed against the back of the tank, and it takes it a minute to fall down and turn on.
the_man is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
New construction, toilet flushes strange. premipet Plumbing 7 02-08-2008 10:30 PM
Toilet flushes slowly, but no visible clogs... poorboye Plumbing 4 09-13-2007 12:02 PM
