Toilet Flush Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2012, 02:30 PM   #1
Toilet flush valve
Hi guys,
I just bought a new flush valve for my toilet and have a question about the rubber gasket that sits directly between the bottom of the tank and the top of the bowl.
Basically, should i use caulking between the gasket and the bowl or will it do the job without?
There was a ton of caulking on the old one but the instructions on the new valve don;t mention anything about caulking.
If i'm supposed to caulk, any suggestions on removing the old caulking to get a clean surface? i cut off as much of it as i could but the silicone residue isn;t coming off with my elbow grease
Thanks guys.
MitNotrof is offline   Reply With Quote
Old 02-06-2012, 02:33 PM   #2
Rewards Points: 14,010
No sealent is needed.
Use a single edged razor blade.
Old 02-06-2012, 08:07 PM   #3
I used a sealant called Block. It's blue and you brush it on.
I also heard you don't need a sealant. A retired plumber told me about it. I figured it couldn't hurt.
Matco88 is offline   Reply With Quote
Old 02-06-2012, 09:20 PM   #4
Rewards Points: 582
don't need a sealant but picture would help see what you have...
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (02-06-2012)
Toilet flush lever problem diyrocks General DIY Discussions 20 12-09-2016 08:12 PM
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Toilet doesn't flush every time Ultrarunner2017 Plumbing 6 03-11-2010 07:18 AM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 06:52 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
