Toilet Flush....maybe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2008, 08:30 AM   #1
Smile
Toilet flush....maybe
I have a toilet, an American Standard Cadet 2 ,which does not alway empty thus requiring a second flush. This happens about 3 out of 5 times. Any body have any suggestions as to what is wrong ?
ehollingsworth is offline   Reply With Quote
Old 10-14-2008, 08:43 AM   #2
Another DIY Zombie
Rewards Points: 264
Could be as simple as toilet design. This is not a super low volume, but still lower than the old 5-7 gallon. I suggest you try and raise the water level a tad and see what happens.
I have a Kohler that I installed a year ago (think it's 1.7 gal.) and has the same issue, just had to raise the level about an inch.
javan is offline   Reply With Quote
Old 10-14-2008, 11:33 AM   #3
One thing to check is the chain/strap that raises the flapper. It should have only enough slack to allow the flapper to seal. If it has too much, the flapper may not raise all the way when flushed and cause a "short flush". This means that the flapper is falling before most of the water has exited the tank.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet Flush Handle skittlzski Plumbing 8 02-22-2009 11:29 PM
Back Flush Toilet Randell Tarin Plumbing 1 04-16-2008 07:33 AM
weird pipe noise after toilet flush bourbonboy Plumbing 1 11-30-2007 05:18 PM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 11:51 AM
