Toilet Floor Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2009, 06:55 PM   #1
toilet floor flange
Hi Everyone long time since my last post anyway Question: I'm redoing my bathroom floor indoing so I removed my camode, I put some luwan sub floor down. I have it right at the floor flange and I just can't remember if I need a spacer on my flange to make it level with the floor or if I can leave it like it is or will it leak? Thanks in advance guys I really appreciate your help!!
joseph44 is offline   Reply With Quote
Old 07-12-2009, 08:41 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
ideally, the underside of the flange ring should rest on top of the floor, and the ring screws down into the floor. But it is fine to have the flange be slightly below the finished floor surface so long as you get a thick wax ring so that there will be a solid connection of wax between the underside of the toilet and the flange to prevent leaks. When you do buy a wax ring, make sure you spend the extra couple of bucks and get the thicker kind with the plastic horn/funnel that helps direct water down into the flange opening. Don't just get the cheap small wax only ring.
adpanko is offline   Reply With Quote
Old 07-13-2009, 09:06 PM   #3
just curious and not to go off topic but is there anything wrong with using the rubber gasket ? I hear you mention wax but not the rubber one .Thanks
dutchdude is offline   Reply With Quote
Old 07-14-2009, 08:16 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
I've personally never used one, but I understand that those newer type rubber toilet seals work just fine. Only problem with them is that codes have not approved them yet in many places, so technically only wax ring types are approved.
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-15-2009, 04:44 PM   #5
camode drain flange
Thanks for the help and your thoughts completed the bath room everything works great I used the wax ring.I was told they don't use the spacer any more they use 2 wax rings instead.Thanks again guys !!
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 01:53 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
