Toilet Flapper - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2013, 11:32 AM   #1
Dave Sal's Avatar
Rewards Points: 662
Toilet flapper
Hey guys,
My toilet flush valve has been leaking with an annoying drip, drip, drip sound. Since the flush valve was original and about 33 years old, I decided to renew everything and bought a Korky Universal Toilet Repair Kit.
http://www.acehardware.com/product/i...ductId=3012884.
I took the tank off and removed all of the old hardware, cleaned it up, and installed the new kit. Everything went back together with no issues. Trouble is, the new flapper has a leak. It can be stopped by moving the flapper a bit, which I assume means that it's not centering itself on the hole. Is there any brand or type of flapper that performs better than others that I could switch to that would solve this problem? Thanks
Dave Sal is offline   Reply With Quote
Old 09-17-2013, 04:26 PM   #2
Plumber
Try buying a new toilet handle, with the inside the tank part made out of medal.
Then bend it so the flapper falls straight down on the flush valve.
DidIDoThat is offline   Reply With Quote
Old 09-18-2013, 03:12 PM   #3
Dave Sal's Avatar
Rewards Points: 662
Update:
problem solved. I drained the tank, applied a thin coating of Vaseline to the underside of the flapper on the sealing surface and no more leaks.
Mini-project: Rebuilt my toilet. First time doing it. r0ckstarr Project Showcase 6 05-13-2014 02:59 PM
Replacing flapper in old toilet joeg679 Plumbing 5 11-11-2010 07:46 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Toilet flapper keeps flipping backwards msammut Plumbing 2 07-04-2008 06:08 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 02:40 PM
