Toilet Flange & Subflooring - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2010, 01:32 PM   #1
Based on the attached images, does anyone think there is enough space to install a flange on the sewer pipe in the restroom? Any recommendations on what I should do?
Sewer pipe diameter: 4"
Tile cut-out diameter: 7.5"
My parent's are having their upstairs bathroom re-tiled and the toilet replaced? The contractor re-tiled the restroom first and is now looking at replacing the flange to the sewer pipe.
I fear that the contractor should have did some modifications to the sub-flooring in order to screw in the new flange.
Toilet Flange & Subflooring-pipe-opening-zoom-.jpg   Toilet Flange & Subflooring-pipe-opening-zoom-out.jpg
Pumpjack is offline   Reply With Quote
Old 02-07-2010, 04:14 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is that a 4" ABS hub that's been painted? The flanges we use TKO I believe are a 4x3, and will either go INTO a 4" hub or on the outside of a 3" pipe. The one you have looks like its broken on one side? That could potentially be a problem, and thats something that would have to be fixed from below now.
Journeyman Plumber
Old 02-07-2010, 07:50 PM   #3
The purple lines the sewer pipe is from the adhesive fluid that was used to join the original pipe and flange.
The contractor damaged the sewer pipe (left side) while prying out the old flange so its a bit chipped.
Old 02-07-2010, 08:12 PM   #4
Licensed Engineer
Rewards Points: 171
Maybe one of these will work...........
They don't list the overall length, but it appears to be a possilbe solution for you.
http://www.ipscorp.com/watertite/clo...es/pushnrepair
It is a push-in to fit inside a 4-inch pipe, and the tail piece can be cut to length.
A bigger challenge may be to cut away the new tile so that you mount this to the sub-floor. Or if the tail piece is long enough, maybe the flange can sit on the surface of the tile - after you use a carbide bit to drill thru the new tile to the subfloor for the anchoring screws.
The same company makes "long pattern" solvent weld closet flanges for 4-inch PVC too. No picture is offered but I assume a long pattern means long neck to compensate for cutting the soil pipe too short.
MI-Roger is offline   Reply With Quote
Old 02-07-2010, 10:26 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
how are you going to anchor the flange to the floor? the floor is so butchered theres nothing to attach to,not to mention the pipe is trashed!
plummen is offline   Reply With Quote
Old 02-08-2010, 12:23 AM   #6
Doing it myself
Alan's Avatar
Agreed. If he damaged the fitting BEFORE finishing the floor, you need to make him fix it. He should have taken care of that before laying down the tile.
Journeyman Plumber
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
