Toilet Flange Sideways - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 04:13 PM   #1
Rewards Points: 320
Toilet flange sideways
Ok, so I did something I said I would never do and i glued my toilet flange on facing the wrong direction. I've seen Oatey makes a twist and set product that I could use, but that seems to me might end up sitting too high off the floor (laying on top of the current one) and might also have a lot of places for "stuff" to get snagged or build up on. In a book i have they said instead of using closet bolts, you can use a heavy duty wood screw to secure the toilet (screwing down through the subfloor). It looks like the screws to secure the flange are pretty closet to where i need the bolts to be, can i maybe make use of this area to slide some closet bolts in or the book recomended approach? I would then screw the flange down with washers over the slotted area. Or do I need to cut the pipe under the house and start over? The floor hasn't been nailed down yet if that makes a difference.
Toilet flange sideways-toilet-flange.jpg   Toilet flange sideways-toilet-flange2.jpg
autx790 is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 06:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
