TOILET FLANGE: Right Position? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2012, 01:22 AM   #1
Rewards Points: 111
TOILET FLANGE: right position?
Hello guys,
This is a another part of my bathroom remodeling project. I am working on installing new Closet Flange before I will level the slab with SLC and put 3/8 12x12 Ceramic Tiles.
The old Flange was all rusty and yacky. I decided to go back with Cast Iron Flange because toilet drain pipe is Cast Iron also. It is sticking out of Concrete Slab by approx 1 3/8".
I chopped concrete with chisel around the pipe, so now new Flange sits lower and 1 1/2" above slab and I calculated that it would be the height of Finished Surface after I put tiles.
Now the question is, will toilet fit on this Flange without any problems since pipe is almost even with the Flange?
Thank you in advance!
almazon is offline   Reply With Quote
Old 02-24-2012, 07:18 AM   #2
The flange top should be flush to 1/4" above the finished floor level.
Old 02-24-2012, 08:05 AM   #3
Rewards Points: 1,418
When the toilet is set down for a test fit, it should be resting solidly on the floor and not touching the flange. The wax ring fills the gap between toilet and flange.
Old 02-24-2012, 08:10 AM   #4
Rewards Points: 616
yes some cast iron flanges had a lead pipe or 90 that would fold on top of toilet flange
i would recommend using a wax ring with a rubber horn but not reinforced ring this can help with paper and solids from snagging on pipe edge
like these
http://www.homedepot.com/webapp/cata...yword=wax+ring
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 02-24-2012, 01:58 PM   #5
Rewards Points: 111
Thanks guys for all of your replies!
This is what I am talking about.
As you may see pipe inside Flange is almost even. Maybe 1/8" lower.
Will I be able to fit the Toilet over this setup? Perhaps with "wax ring with a rubber horn"?
Or if I will set the Flange 1/4" higher so it will sit on top of finished surface?
Thanks again,
almazon
Old 02-24-2012, 02:47 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 348
Buy the bowl wax you want to use and see if it sits down on the flange - seeing is believing
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-24-2012)
Old 02-24-2012, 06:42 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Which way are the slots oriented in relation to the walls?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-24-2012, 09:17 PM   #8
Rewards Points: 111
The holding bolts on old Flange didn't go through the slots, but instead through cut-outs on the side of the Flange. I was planning to do the same (thats why its oriented this way), but then, after talking to few ppl, I realized slots would be most proper idea.
Old 02-24-2012, 11:37 PM   #9
plummen's Avatar
Either way will work m,but sliding them in from the sides will be a little tough if you tile up to the flange is all
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 09:39 PM
