Toilet Flange Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2010, 03:52 PM   #1
Rewards Points: 272
Toilet flange question.
I am about to finish running a toilet drain line on freshly installled subfloor. I'd like to eventually install tile but for right now I want to install the toilet directly on the subfloor for use until I'm ready to tile.
Problem is if I install the drain flange at the subfloor level I'll have a problem when it comes time to tile it. THe flange will be too low. If I install the flange at a higher height to compensate for the future tiling (~1/2") then my toilet won't fit for use right now.
How can I get around this?
speedster1 is offline   Reply With Quote
Old 04-06-2010, 03:59 PM   #2
install flange on subfloor. when it comes time to tile they make spacers you can use to raise elevation. as long as your not putting in a 2-3" wet bed
just a guy is offline   Reply With Quote
Old 04-06-2010, 04:48 PM   #3
Rewards Points: 352
Install at finished heigth, shim toilet to match
plumberinlaw is offline   Reply With Quote
Old 04-06-2010, 08:16 PM   #4
Rewards Points: 1,512
Originally Posted by plumberinlaw View Post
... shim toilet to match
You could cut one large continuous "shim" as a ring of say 3/16" to 3/8" (as needed) plywood or hardboard for the toilet to sit on.
Old 04-07-2010, 10:30 AM   #5
Flange extenders are available at Home Improvement stores. They are available in different thicknesss, starting at 1/4". Make sure you use a sealer between the spacers and the original flange, and screws to attach the spacers through to the floor. Click on the link below to see a picture of an extender. Note, the holes in the extender for securing to the floor.
http://plumbing.hardwarestore.com/51...ng-117838.aspx
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
Toilet Flange cody21 Plumbing 10 09-08-2009 02:31 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 08:07 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
Removing old toilet flange craftycas Plumbing 3 02-22-2005 11:59 AM
