-   -   Toilet flange question. (http://www.diychatroom.com/f7/toilet-flange-question-68446/)
speedster1 04-06-2010 03:52 PM
I am about to finish running a toilet drain line on freshly installled subfloor. I'd like to eventually install tile but for right now I want to install the toilet directly on the subfloor for use until I'm ready to tile.
Problem is if I install the drain flange at the subfloor level I'll have a problem when it comes time to tile it. THe flange will be too low. If I install the flange at a higher height to compensate for the future tiling (~1/2") then my toilet won't fit for use right now.
How can I get around this?
just a guy 04-06-2010 03:59 PM
install flange on subfloor. when it comes time to tile they make spacers you can use to raise elevation. as long as your not putting in a 2-3" wet bed
plumberinlaw 04-06-2010 04:48 PM
Install at finished heigth, shim toilet to match
AllanJ 04-06-2010 08:16 PM
Originally Posted by plumberinlaw (Post 424929)
... shim toilet to match
You could cut one large continuous "shim" as a ring of say 3/16" to 3/8" (as needed) plywood or hardboard for the toilet to sit on.
majakdragon 04-07-2010 10:30 AM
Flange extenders are available at Home Improvement stores. They are available in different thicknesss, starting at 1/4". Make sure you use a sealer between the spacers and the original flange, and screws to attach the spacers through to the floor. Click on the link below to see a picture of an extender. Note, the holes in the extender for securing to the floor.
http://plumbing.hardwarestore.com/51...ng-117838.aspx
