Toilet Flange Ontop Of Or Level With Tile? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2006, 04:48 PM   #1
Toilet Flange ontop of or level with tile?
I'm getting ready to tile my bathroom. Should I put the flange in now level with the mud then tile around it? Or should I put the tile down then install the flange ontop of the tile?
Also, this is the flange I have is this any good or should I use something else? I figure a cement in one will probably hold up much better then one of those twist in ones?
Tmb9862 is offline   Reply With Quote
Old 11-23-2006, 08:32 PM   #2
DIY'er
Rewards Points: 150
The toilet flange should be on top of the finished floor.
Doug Russell
"What if the hokey pokey really IS what its all about."
dougrus is offline   Reply With Quote
Old 11-23-2006, 09:41 PM   #3
I agree that it should be on top the tile. Don't forget that the flange has to be secured to the floor. Get a good masonary bit to drill the tile without cracking them. Since it is likely that you will have a tile saw handy, you may be able to trim the tile (cut notches) so the flange mounting holes are open and not need to drill. A small notch would still give plenty of stability for the flange and negate the possiblity of cracking when drilling.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-24-2006, 08:40 AM   #4
DIY'er
Rewards Points: 150
Yes... good advice. Make sure you secure it the floor well.
Something else to chew on; lots of people are buying porcelain over standard cermamic these days, as I did in my bath. When you try to drill into that stuff, be sure you buy a specialty diamond bit from a tile supply. Depending on what grade you get, it can be very very hard. The big boxes sell carb bits and masonry bits but the porcelain will laugh at them.
Doug Russell
Old 11-24-2006, 09:10 AM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Use stanlees steel screws or all brass screws only to secure flange to floor.
Ron The Plumber is offline   Reply With Quote
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 09:34 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Removing old toilet flange craftycas Plumbing 3 02-22-2005 12:59 PM
