Toilet Flange Not Level - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2013, 03:58 PM   #1
Rewards Points: 242
Toilet flange not level
Hello everyone,
I'm currently renovating a basement bathroom, and recently had the toilet and sink roughed in. I've since pour new cement and now notice that the toilet flange does not sit level. It sits level from side to side, however the front is approximately 1/4 inch higher than the back. The toilet mounting ring is 1/4 inch thick and sits on top of the cement. The floor I'll be installing will measure about 1/2 an inch by the time it's done with underlay etc.
I'm looking to know if the flange will cause me any problems. I figure my options are to cut it out and replace it with an inside fitting flange. If I do this I believe the toilet mounting ring should sit above the finished floor. Is that correct or should it sit flush with the finished floor?
If I can leave the flange, is there something I should be doing when installing the toilet? I've heard of people using two wax rings to ensure a proper seal and thought about doing this since the mounting ring will be slightly below the finished floor.
Thanks for your help!
Lemkie is offline   Reply With Quote
Old 02-23-2013, 04:45 PM   #2
jproffer's Avatar
Rewards Points: 716
The flange should have been on top of the finished floor from the beginning.
As it is now, a wax ring should take up the space you're talking about when you install the toilet....if one wont, 2 will.
jproffer is offline   Reply With Quote
Old 02-24-2013, 02:48 AM   #3
Rewards Points: 242
Great. Thank you!
The Following User Says Thank You to Lemkie For This Useful Post:
oh'mike (02-24-2013)
Old 02-24-2013, 08:01 AM   #4
Rewards Points: 1,538
One small note. Since the flange is above the floor surface, you need to do a test fit without the wax ring and be sure that the toilet bottom does not touch the flange at all. Otherwise minor stresses and settling could crack the toilet. Use shims all the way around the toilet if needed.
AllanJ is online now   Reply With Quote
Old 02-24-2013, 08:49 AM   #5
Rewards Points: 242
I will be sure to do this first! Thanks!
toilet flange Dave43026 Plumbing 3 11-05-2011 10:25 AM
Cracked Toilet Flange BLAKE1982 Plumbing 1 01-11-2009 05:31 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 11:37 AM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 09:41 AM
