Toilet Flange Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2014, 03:25 PM   #1
Rewards Points: 39
toilet flange issue
Hi I am renovating a bathroom. I just removed the old floor tile to find that the sublfoor is in 2 parts. 1 part 1/2 inch particle board and the other half is self levelling cement.
The toilet flange is screwed into the self levelling cement. I have removed a lot of the cement around it. The flange is one long piece that goes down into the floor.
Should I remove it and put the subfloor down and then cut the hole and put a new flange in? Not sure how the flange is attached at the bottom. WHat a mess!
Here are some pics.
http://s11.postimg.org/3yrsve0xf/flange1.jpg
tiki16 is offline   Reply With Quote
Old 02-25-2014, 04:18 PM   #2
Rewards Points: 12,824
Easiest way to deal with it is to go below the floor and just cut off the pipe and pull the whole thing out.
You do know all that old subflooring has to go .right?
Old 02-25-2014, 05:06 PM   #3
DL's husband's Avatar
Concur with Joe. Cut it and then install a collar and a section of piping (3" or 4" depending upon the size) and leave the pipe standing 'as is' until you get the floor completed. Then depending how long it is/how far down it goes, you can proceed from there.
Once you get the floor installed, the top of that flange must be 1/4" above the finished floor. You can be off a bit, but stay as close to 1/4" as possible.
Craig in southeastern Virginia
Navy veteran July 1980 - August 2007
DL's husband is offline   Reply With Quote
Old 02-25-2014, 05:37 PM   #4
Rewards Points: 39
I am removing sub floor. How deep should i cut? It seems impossible to get a saw in a horizontal angle to cut it?
Old 02-25-2014, 06:24 PM   #5
If you can't get enough room under the subfloor, and have a drill (electric or battery operated) there are internal pipe cutters you can buy. Such as this one (hopefully the picture attachment works).
Old 02-25-2014, 07:03 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 350
Check to see where the 90 is at below the flange. They may be close coupled. Cutting it might produce another problem...
Can you access the bottom side?
Old 02-25-2014, 08:43 PM   #7
Rewards Points: 39
the 90 is 18 inches down. I am on the second floor. Can you get that saw drill bit at HD? I just picked up an oscillating saw but it won't help me get down there.
Old 02-25-2014, 08:48 PM   #8
Plumber
Rewards Points: 350
HD should have it in the plumbing dept. I suggest you stuff a rag down the pipe- below your cut line. Those bits come loose in the drill chuck and fall out. Then you need a big magnet to retrieve it.....
Old 02-25-2014, 10:25 PM   #9
That's where I got mine. In the aisle where they have the repair pairs.
Old 02-25-2014, 11:07 PM   #10
Rewards Points: 39
Look what I've uncovered. Any suggestions?
Old 02-26-2014, 12:49 AM   #11
Just looks like every old house I've ever work on before.
Think you found your reason it was leaking and rotted out.
Just go rent or buy a Toe kick saw or even a sawsall with a short wide wood cutting blade and cut out the rest of those floor boards.
Install all new 3/4" thick Advantech subflooring with construction adhesive on the joist.
The subflooring and flange needed to be installed above the joist not along side of it.
Old 02-26-2014, 09:02 AM   #12
Yep.
Remove and replace the subfloor. What Joe suggested is good. Yet I'd shoot some deck screws also since those joists aren't in the best shape.
Since this project is going to grow, start thinking a couple of steps ahead (such as the height of the finished floor when your done, new vanity/toilet, etc.).
Are you planning to lay tile or laminated sheeting (linoleum)?
Old 02-26-2014, 05:57 PM   #13
Rewards Points: 39
What if I leave the 1/2" plywood sub floor to the left of the pic and install 1/2" beside it and then go 1/2" plywood 5'x5' over the whole area for a total 1" sub and lay tiles on top?
thanks
Old 02-26-2014, 09:05 PM   #14
#1, 1/2 subflooring is useless as a subfloor.
All it does is act like a shim sitting on top of the joist.
#2, It's going to just be adding to your finished height and add almost no strength.
Sure looks like an older home, what that tells me is under sized over spanned joists, uneven floors from sagging, and floor bounce.
Once the old sub floorings gone the joist can be sistered for added strength and allow for leveling.
If your going to tile your going to need that 3/4 T & G subflooring and at least 3/8 underlayment rated plywood over that.
Then you'll need 1/4 tile board set in a bed of thin set.
tiki16 (02-26-2014)
Old 02-26-2014, 09:11 PM   #15
Plumber
Rewards Points: 350
thanks
tiki16- I recommend that you start a new thread about your subflooring over at http://www.diychatroom.com/f19/. This will give you more exposure to that issue and this thread will continue to address your flange install/repair. Thanks
Tags
flange , sub floor , toilet
Re-cementing around Toilet Flange & Flange installation for Tiling Floor crayola110 Plumbing 7 09-22-2012 01:02 AM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
Toilet Flange Dilemma (W/ Pics) Rotate Plumbing 5 06-19-2011 07:00 AM
Cracked Toilet Flange BLAKE1982 Plumbing 1 01-11-2009 06:31 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 08:40 PM
