-   -   Toilet Flange Inside or Outside Drain Pipe? (http://www.diychatroom.com/f7/toilet-flange-inside-outside-drain-pipe-69943/)
sledged 04-27-2010 12:53 AM
Let me start by saying this is an awesome forum I stumbled upon tonight and am glad I did. Everyone seems real very helpful from the extensive searching I have done to try and answer my question. I have not been able to find my answer so I thought I'd throw out my own question for you guys to help me out.
I am remodeling the bathroom in my condo and want to replace the toilet flange before i tile the floor but I want to make sure I do this right as I cant afford leaking onto my neighboor below. The drain pipe below the toilet is 3 inch diameter PVC pipe which had a destroyed cast iron flange over it. I removed the old flange and I was wondering if I could put a new flange that would fit inside the PVC pipe or do I need to get a flange that will go outside the PVC drain pipe so that I dont restrict the flow and cause clogging when the toilet is installed. I would like to put a flange that would go inside the drain pipe as i feel this would be less likely to leak. Is there a flange I can purchase at home depot or should I get a specialty one from a plumbing supply store? If anyone can shed light on this issue I would appreciate it. Thanks everyone in advance.
Just Bill 04-27-2010 05:58 AM
Always inside. But it is unusual to find an iron flange in a PVC pipe, how was it fastened. There should be a hub on the PVC, if not, use a Fernco sleeve to secure things.
oh'mike 04-27-2010 06:16 AM
Inside works fine---properly installed the outside ones also work well.
The flange should be installed before the tile---tile is cut around the flange.
If the ring is a bit low--you can get a thicker wax ring-------
However---if the flange is to high--there may not be enough room for your wax ring.
--Mike--
speedster1 04-27-2010 09:40 AM
1 Attachment(s)
--Mike--
I thought the new flange should be installed after the tile is laid with the flange sitting directly on top of the tile. With the new flange going inside the existing drain pipe.
At least thats how I did mine this past weekend. :eek:
plumberinlaw 04-27-2010 09:51 AM
Either way, your toilet probably has a 2" or 2 1/8" outlet
zircon 04-27-2010 10:34 AM
I admire your courage. I live in a condo and I rebuilt my bathroom, new shower ,fixtures etc. but I am on the ground floor. If I messed up, the leak would be into the basement. I would never have tried it if I lived on a higher floor with other owners under me. Huge potential grief from the person under you, the Board of Managers etc.
JakAHearts 04-27-2010 02:30 PM
In my bathroom, the entire flange was exposed and they have a larger repair flange bracket holding it underneath and to the subfloor. I didnt think it was right but it still worked. Ive since made it look like your diagram and that also works.
Shane
speedster1 04-27-2010 02:42 PM
1 Attachment(s)
Shane
The diagram should really look more like this. I cna't imagine putting in a flange that went outside teh drain pipe. Seems like a disaster waiting to happen.
It's like when you put tar paper on a roof you start at the bottom and overlap as you go upwards. If you did it the other way around rain would be able to flow under the lower tar paper :(
JakAHearts 04-27-2010 03:28 PM
Ah I didnt even notice that part of it. I was only looking at the relation to the tile/floor. My flange is inside the pipe.
Shane
Jim F 04-27-2010 04:38 PM
As I understand it the flange should be flush with the tile if possible, not sitting on the tile but I think it can be adapted to work either way.
sledged 04-27-2010 08:39 PM
Excellent advice guys, thanks again, makes me lil more confident when installing the new flange. Now for one more question I forgot to ask, how would you guys suggest removing the left over plastic from the old flange that is still glued into the drain pipe? The drain pipe sticks up out of the ground and seems to have some extra slack so I was thinking of cutting off the old flange with minimal reduction of the drain pipe length as possible. Anyone have any other suggestions? Its appreciated.
oh'mike 04-27-2010 09:11 PM
If the inside of the pipe is damaged with glue--consider using the flange that glues to the outside of the pipe.
I was serious about setting the flange first and then tiling up to it.That is the proper method.
I do kitchens and baths for a living. You can run into serious problems setting the flange on top of the tile.
Ask the plumbers if you don't believe me.---You do not want to be drilling into your tile to secure the flange to the sub floor?
If my count is correct I've done 17 bath remodels in the last year---Put the flange first--then the tile.
---Mike---
mrlouie 04-27-2010 11:58 PM
If it's properly glued it shouldn't matter if it's inside or outside of the pipe... couplers, elbows, wyes and tees always will have one end with the wrong "overlap" from your analogy. They don't leak when primed and glued correctly, even when horizontal.
speedster1 04-28-2010 05:27 AM
Good Point :)
how2do 01-29-2011 10:46 PM
Toilet Flange Height
The flange should be mounted on top of the finished floor. No number of wax rings stacked will keep the toilet from leaking in the future. I found this product called "Set-Rite Extender Kit" it works with both new installations and remodel jobs. The kit has a flange gasket and also works with a wax ring. The company has an installation video on YouTube and their website. Saved me a lot of time and money.
http://www.youtube.com/watch?v=5XeTjnH7OUc
