Old 02-17-2010, 12:19 AM   #1
Toilet Flange Help
I just poured some self leveling compound to even out the bathroom floor before I tile. I had a 1 gallon bucket centered over the toilet flange, but it somehow moved to one side.
What's the best way to attach the flange at this point? Should I chip away at the SLC to allow the flange to be bolted directly to the wood, or...?
Here is a photo...
HenryG is offline   Reply With Quote
Old 02-17-2010, 03:38 AM   #2
jlhaslip's Avatar
Toilet Flange Help
Grinder or dremel would be less likely to disturb the compound.
Messier though.
Wear protection.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-17-2010, 10:31 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Toilet Flange Help
what kind of flange is that and why wasnt it attached to floor when it was installed?
plummen is offline   Reply With Quote
Old 02-17-2010, 03:36 PM   #4
Toilet Flange Help
I don't know the correct name, but the part that was attached to the previous floor I took off before I put down the SLC. Looking back I should have at least set it there when I covered that area. I don't think I can use to old peice because the new floor is slightly higher. From what I understand I can buy an extender of sort to make up the difference.
Old 02-17-2010, 06:57 PM   #5
plummen's Avatar
Toilet Flange Help
is that part of a no-seep wax ring stuck in the pipe?
Old 02-18-2010, 04:20 PM   #6
Toilet Flange Help
Yes it still needs to be cleaned up a little.
Old 02-18-2010, 04:28 PM   #7
plummen's Avatar
Toilet Flange Help
that small hole in the center was screwing with me!
Old 02-18-2010, 06:39 PM   #8
Toilet Flange Help
Can't honestly say I really messed with it too much. Now that I really look at it in the photos it does look a little odd. Next time I'm at the house I'll get a better look, and maybe more photos. All I did was remove the flange from the old plywood, and lay down new stuff.
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
