Toilet Flange Height Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2014, 07:01 PM   #1
I have gutted my basement bathroom and am in the process of re-doing the whole thing. I removed the old tile floor and instead of replacing it, I decided to acid etch, stain, and seal the concrete. Now I noticed that the flange is 5/8 of an inch above the new floor level. I am planning on using a Sani-Seal wax free toilet ring if that makes any difference.
Is 5/8 in above too high?
Should I cut tile to fit just under the toilet and caulk it in?
Zefrik is offline   Reply With Quote
Old 04-28-2014, 07:42 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Lower the flange. Chip out the concrete if required. What material and size is the pipe?
Coastal South Carolina
Old 04-28-2014, 07:44 PM   #3
Zefrig, I would. Placing the toilet on the unsupported flange is asking for trouble. A bonus to this approach is you get a slightly elevated toilet; when your my age the higher it is the better
BatocheBob is offline   Reply With Quote
Old 04-28-2014, 08:17 PM   #4
I think the pipe is old and rusty....the house was made in the mid 70's and I think it is original. I have scraped the flange clean.
I would like to avoid removing any concrete if possible. I don't think I am up to the task.
Do you not think the tile is a good idea?
Old 04-28-2014, 08:35 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 676
Nothing wrong with setting a toilet on tile. In your case it's the visual looks that might not work. But if you're happy with it- thats what counts
Your flange is too high right now so you either lower it or shim with a tile floor
Tags
flange , floor , height , toilet
Basement toilet redo, toliet flange question EllijayWoodWork Plumbing 10 12-31-2012 02:00 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
Installing new toilet - flange question ncstevem Plumbing 7 12-18-2010 05:45 PM
toilet flange height Unregistered Plumbing 1 01-27-2004 01:51 PM
