Toilet Flange Height - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2010, 07:07 AM   #1
Joe F's Avatar
Rewards Points: 294
Toilet flange height
I'm tiling a basement bathroom floor (concrete slab). The toilet flange is currently about 1/4" above the the floor. Once the tile is down, I expect that the flange will be about 1/4" below the finished floor height. Will the wax ring accomodate this or do I need to extend the flange?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 10-22-2010, 07:41 AM   #2
Just call me Andrew
Rewards Points: 1,020
Probably, they have pretty thick rings. But they also have little flange extenders you can buy, probably at the big box stores:
Andrew
secutanudu is offline   Reply With Quote
Old 10-22-2010, 08:49 PM   #3
Homerepairguy's Avatar
Rewards Points: 990
There are two thicknesses of wax rings, standard and double thickness AFAIK. Measure the distance from the flange to the toilet and see if a double thickness wax ring will work. You may need to measure the thickness of the wax rings at your hardware store to be sure.
Homerepairguy is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
estimating flange height for rear outlet toilet JakAHearts Plumbing 6 07-04-2010 05:53 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
toilet flange height Unregistered Plumbing 1 01-27-2004 02:51 PM
