Toilet Flange Extension Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2009, 09:06 PM   #1
Rewards Points: 1,562
Toilet flange extension question
I'm putting in a porcelain floor in our powder room and assume I'll have to use a toilet flange extension/spacer to raise the toilet drain flange surface level to the new floor height. When you add these spacers, should silicone sealant be applied between the spacer ring and the existing flange? If not, is anything needed or will the wax ring keep things leak free?
Tia,
Bob
bob22 is offline   Reply With Quote
Old 12-18-2009, 08:49 AM   #2
47_47's Avatar
Rewards Points: 44
Silicone caulk and screw it to the subfloor.
47_47 is online now   Reply With Quote
Old 12-18-2009, 10:04 AM   #3
If the extender ring does not have a seal on it (some do, some don't) use the silicone and make sure you screw it down through to the subfloor using the holes provided.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-18-2009, 06:41 PM   #4
Thank you both!
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet question ssteel Plumbing 11 12-12-2009 10:38 AM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
Removing old toilet flange craftycas Plumbing 3 02-22-2005 12:59 PM
