Toilet Flange Extender - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2010, 07:43 PM   #1
I have installed ceramic tile in my bathroom which has raised the level of the flooring. I understand you can add a flange extender to the exsisting flange to raise the level. This bathroom is on the second level and my question is how reliable are these flange extenders? Will I be able to detect a leak?
TRACKER is offline   Reply With Quote
Old 07-26-2010, 10:04 AM   #2
Retired Plumbing Cont.
Personally, I don't like the extenders. If the flange is now below the new finished floor, then it should be cut out and raised. If it is at least level with the floor, then you might try using two wax rings, one regular and one with a horn. Put the regular wax ring on the flange first then put the one with the horn on top of it. That will allow the horn to center the rings when you press down on the toilet. Be sure the toilet is secure to the tile with no rocking. Use shims if needed. Flush several times to check for leaks. Take some of the grout that was used on the new floor and apply around the base of the toilet.
rockerjockey is offline   Reply With Quote
Old 07-26-2010, 10:21 AM   #3
Flange extenders work fine,if properly installed. I use silicone caulk between the extender and the original (cleaned) flange. The extender must be secured through the original flange to the sub-floor. This is why they have the holes, that will line up with the existing flange holes.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
Toilet Flange Questions LeviDIY Plumbing 13 06-04-2009 02:22 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
