Toilet Flange Dilemma - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2014, 08:09 PM   #1
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Hey all,
I have a dilemma with installing a toilet flange in a basement bathroom I'm adding. The neck of the toilet flange is 2-1/8" long. But I will only have about 1-1/2 inches to slide it on to the 3" pipe. The pipe is embedded in concrete except for the 1" of SLC I poured around it where I gave it plenty of room for the flange. And once I add tile, I'll gain an additional 1/2". So that's a total of 1-1/2" for the flange. Can I cut the flange neck down to 1-1/2"? Or do I risk breaking the pipe by chiseling out concrete (this scares me)? Do they sell shorter neck flanges? Any advice appreciated.
Also, I'm guessing I should avoid a flange that goes on the inside since it's a 3" pipe.
Thanks,
Jon
jonhayden is offline   Reply With Quote
Old 04-11-2014, 10:36 PM   #2
Rewards Points: 920
I've done the flange that goes on the inside and it wasn't a problem.
cleveman is offline   Reply With Quote
Old 04-11-2014, 10:54 PM   #3
Want to Learn
jonhayden's Avatar
Rewards Points: 135
And you did that on a 3" pipe? I think that's what I might have to do, but I don't want to deal with continuous clogs.
Old 04-11-2014, 11:13 PM   #4
Rob
Robpo's Avatar
Rewards Points: 826
That's a tough call. If you chisel it will probably scratch or gouge the pipe and that won't be good. If you have a hammer drill you could cut the flange and put tap cons in the flange which should work. If you have a chipping gun or hammer drill with a chipping bit. I don't know. Your call. Wish I could of been more of a help.
edit-There might be insulation around the pipe where it comes through the slab under a thin layer of the old concrete if the house isn't that old. Just a thought.
Robpo is offline   Reply With Quote
Old 04-11-2014, 11:22 PM   #5
Rewards Points: 1,700
Chisle the concrete it is no big deal
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (04-12-2014)
Old 04-11-2014, 11:30 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 352
Plumbers chisel all the time. Or cut the hub down to 1.5"
Dont glue inside a 3" pipe though
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-12-2014), COLDIRON (04-12-2014), oh'mike (04-12-2014)
Old 04-12-2014, 12:19 AM   #7
Lord of Slums
Rewards Points: 1,974
This makes sense , my tenants are always calling me a chiseler.
mj12 is offline   Reply With Quote
Old 04-12-2014, 07:05 AM   #8
Rewards Points: 920
I believe I went on the inside of a 3" pipe, if such a flange is available. It was something I left stubbed up and came back a number of years later and installed a toilet.
I don't know of any troubles with the installation. The 3" pipe probably drops right into a 4" because it is near where the sewer leaves the house and I had a length of 4" pipe there with a lot of stuff emptying into it.
Old 04-12-2014, 08:11 AM   #9
DIY staff
Rewards Points: 7,174
On a 3" pipe--always use an out side flange---the inside flanges have a small opening--often the toilet outlet horn will hit the flange --and not allow the toilet to seat---get out your chisel---
Old 04-12-2014, 12:19 PM   #10
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Yeah, this was my fault I actually moved the rough-in and poured new concrete. I did wrap the pipe in sill seal, but I miscalculated how low to go on the pipe. It did a great job for the SLC, but barely touched the concrete.
Old 04-12-2014, 12:19 PM   #11
Want to Learn
jonhayden's Avatar
Rewards Points: 135
I think I'll try this a little to see how it goes. Thanks.
Old 04-12-2014, 12:22 PM   #12
Want to Learn
jonhayden's Avatar
Rewards Points: 135
I found a flange at Home Depot that slides inside, but has a gasket instead of gluing it in. You can see it here. What do you think about that?
Old 04-12-2014, 12:23 PM   #13
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Thanks! I'm pretty sure I'm 3" all the way.
Old 04-12-2014, 12:26 PM   #14
Want to Learn
jonhayden's Avatar
Rewards Points: 135
HaHa! I hear ya. Do you think it's acceptable to cut the flange shorter? Maybe chisel out a little more but also cut the flange shorter. I've seen other types of flanges with shorter necks so I'm wondering how important the length of the neck is.
Old 04-12-2014, 12:41 PM   #15
Plumber
Rewards Points: 352
I highly discourage inside flanges on 3" pipe.
Firstly, 3" is the smallest allowable size per code.
Secondly, as stated in a post above, often times the inside flange will not let the toilet seat properly. You won't know this until after the wc is set, then your back to square one- installing the proper outside flange.
Don't dodge 20 minutes of chipping time by getting the inside flange- it's not worth the risk-IMO
ben's plumbing (04-12-2014), jonhayden (04-12-2014), oh'mike (04-12-2014)
Toilet flange question clambake6 Plumbing 18 03-07-2013 10:25 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet Flange Dilemma (W/ Pics) Rotate Plumbing 5 06-19-2011 07:00 AM
