Toilet Flange On Concrete Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 01:24 AM   #1
MigitLuver's Avatar
Toilet flange on concrete floor
I am replacing my tile floor and toilet. When I got the old tile out I noticed that the floor bolts were coming out of the concrete and there was no flange. I am considering cutting old bolts and installing flange. I also will be using a self leveling compound to even out the floor before tiling.
Should I plug the toilet drain hole with a rag, use self leveler, then install flange after it sets? Or maybe set the flange a little high and let the self leveler fill in underneath?
Thank you in advance for any advice.
MigitLuver is offline   Reply With Quote
Old 01-31-2012, 01:44 AM   #2
Missouri Bound's Avatar
The flange sits on top of the finished floor.
Do you want it your way or the right way?
Old 01-31-2012, 09:03 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
This is debate-able.
To the OP :
Sounds like you just have a cast iron pipe sticking up that was cut flush with the concrete, and then bolts were sunk into the concrete to hold the toilet down?
How much do you plan on raising the floor?
Journeyman Plumber
Old 01-31-2012, 07:28 PM   #4
Rewards Points: 582
as alan said you get many ideas on this ..I like to set flange on finish floor after tile....
Old 01-31-2012, 07:45 PM   #5
Rewards Points: 1,492
If the bolts coming out of the concrete are still solidly in place and long enough then they can be used as-is. You can get an "extension flange" to fit in the existing drain opening and fit over the existing bolts if the toilet bottom plus wax ring doesn't reach.
AllanJ is online now   Reply With Quote
Old 01-31-2012, 10:40 PM   #6
Can we see pictures of this franken-flange setup you have? Is the "toilet opening" a cast iron/pvc waste line? Or whats left of a lead bend? It could be a lead bend which had it's flange ripped off, then someone cemented in franken-bolts. Without seeing what your describing sounds dicey, especially if your laying a nice new floor down. Nothing worse then having to chop your new floor a year later.
PlumbDumb is offline   Reply With Quote
Old 02-02-2012, 02:38 PM   #7
MigitLuver's Avatar
There is one bolt still sticking out of the floor. The other broke off. It is a PVC pipe and yes, it is cut off flush with the floor. I will try to post the pic.
Old 02-02-2012, 02:53 PM   #8
MigitLuver's Avatar
I think the photo is attached. The concrete dips slightly around the drain hole. You can see the spot on the left of the hole where the broken bolt is.
Old 02-02-2012, 06:06 PM   #9
It would be funny to find out it was an actual toilet flange, with bolts in it, that someone skim coated with cement. Maybe they raised the floor up and left the old flange.
You could fix this one of 2 ways. Or both if the first leaks.
Home Depot has these "homeowner special" pvc toilet flanges. Basically you shove it into the inside diameter of a 3" waste line, and it flairs out into a standard flange. In the extra space around the flange (the "track" the bolts slide around), you drill for a molly on each side and screw the flange down to the floor (or if your particular flange has screw holes, molly through them). Make sure your not drilling into a pipe below.
For this to work, you cant build up the rough floor too high and keep the pipe out of the new flange's reach, when you drop it down on top of the finished floor and into the pipe.
What are your plans for the floor?
Old 02-02-2012, 07:18 PM   #10
MigitLuver's Avatar
I only need a very thin layer of self-leveler. Just enough to fill the divots and keep any old mortar from allowing the tile to lay flat. I'd say 1/8" - 1/4"
Old 02-04-2012, 05:36 PM   #11
You should be ok with that inside diameter flange. Before you commit to this way you should get the flange first to
1) make sure you can get one in your area
and 2) you can measure the actual piece that will stick into the pipe, and you can figure out if your higher floor will be too high.
The Following User Says Thank You to PlumbDumb For This Useful Post:
Missouri Bound (02-04-2012)
Old 02-07-2012, 10:10 AM   #12
MigitLuver's Avatar
Ok, I put in the flange. The opening was slightly too narrow so I used my utility knife to taper the top. I pushed the flange down and used Tapcon screws to secure it to the floor. I poured self level and that will hopefully help seal/keep it secure. I installed the toilet last night and it has the very slightest of unbalance but only if I push down on the back of the tank. When you sit on the seat it feels very stable. Have not used it due to the tub faucet needs to be replaced so I can turn water on to bathroom. Thank you so much for all the help and ideas.
Old 02-07-2012, 10:35 AM   #13
Rewards Points: 2,516
On going debate....My vote is bottom side of flange on FINISHED floor.
hammerlane is offline   Reply With Quote
Old 02-07-2012, 06:22 PM   #14
You needed to test fit the toilet and correct all imbalance before putting in the wax ring.
Any imbalance will squish the wax ring a little more than it should be and the ring does not spring back so it will leak.
Old 02-09-2012, 09:24 PM   #15
MigitLuver's Avatar
I didn't install the flange ON the tile but it seems very secure. I had already installed with wax ring and have been using it without leaks. I guess if it ends up leaking I'll just replace wax ring and shim the toilet at that time. It doesn't rock at all when you sit on it.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Toilet floor flange Sweetchuck Plumbing 15 05-20-2012 09:06 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 06:46 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
