Toilet Flange In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2011, 02:55 PM   #1
Rewards Points: 640
toilet flange in basement
I am redoing my basement bathroom, it previously had vinyal flooring in place... I ripped that up and want to put tile in instead, which will raise the floor at least 1/4"... the current flange is littearly level (so that the top of it is at the same height) with the concrete.. what can I do to extend this to the correct height when the tile goes in? I assume this is PVC cemented in?
BlueBSH is offline   Reply With Quote
Old 02-23-2011, 03:07 PM   #2
Coatings Nerd
Taller wax ring with a flange, and probably some longer bolts...thats what mine needed anyways.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-23-2011, 03:09 PM   #3
Rewards Points: 640
noticed the werid thing is that the current flange is now bolted down to the concrete, does this matter at all?
Old 02-23-2011, 03:12 PM   #4
Coatings Nerd
There should be a wax ring...its either stuck in the hole, or to the bottom of the toilet if you took the toilet off already.
Old 02-23-2011, 03:14 PM   #5
Rewards Points: 640
I already removed the wax and cleaned up where it was to see the shape of the flange, what I have left now is a white PVC flange that isn't bolted down just glued I think into the PVC pipe in the concrete
Old 02-23-2011, 03:33 PM   #6
Coatings Nerd
Thats what the wax ring sits on I believe.
Old 02-23-2011, 03:46 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 900
Ideally you want the flange to be on top of the flooring. It should also be anchored to the floor. If not, theres a good chance that the toilet will rock and the wax will loose it's seal. To extend the ring, google "toilet flange extension"
Old 02-23-2011, 05:19 PM   #8
Rewards Points: 16
You can purchase toilet flange extensions at any of the big box stores. They are a couple of bucks and are about 1/4 to 3/8" thick. Just sit on top of current flange and screw into floor add a new wax ring and you are ready to go.
Whaler Man is offline   Reply With Quote
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Toilet Flange cody21 Plumbing 10 09-08-2009 02:31 PM
Toilet Flange Questions LeviDIY Plumbing 13 06-04-2009 01:22 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 09:41 AM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
