| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Remove a Toilet
by Expert Village
Today we’re replacing a dead toilet, one that leaks real bad. What we’re going to do is after you clean the area and get everything all prepped, you’re going to disconnect the water supply. We already have the water turned off. You just... Read More »
Re-installing a Toilet
by Expert Village
The important thing to re-installing a toilet over its location is you put the toilet; let's say it's over the pipe right now. We try to rock the toilet. If the toilet rocks, we need to pre-shim it. We're going to put shims down ahead of time, so when we... Read More »
Wax Ring Maintenance for Toilet
by Expert Village
All right, so we notice that the wax ring is a little low on this side, so when we reset the toilet we're going to keep an eye out to make sure that that has the proper amount of wax on there. We want to remove all the excess wax; make sure we don't get... Read More »
Removing a Toilet
by Expert Village
Now, before we pull a toilet, we've emptied the tank for the water. That was easy, but we need to empty the bowl of the water. So what we'll do is we'll pour a bucket of water; half a bucket of water in the toilet, and we'll pull it kind of fast, and the... Read More »
Tips on Toilet Cuts & Four-Sided Cuts with a Tile Saw
by Expert Village
I showed the toilet cut; that is where you are coming around the flange of the toilet. What we showed here was that you could kind of rough it in. Maybe you cut a few pieces in with the larger saw and then with the grinder fitted with the dry blade and... Read More »
