Old 10-09-2009, 11:56 PM   #1
Default toilet flange
Hay guys! I ripped up my old ceramic tile floor and replacing with new ceramic tile.i found plywood sub floor i am going to put down 1/2 cement board and then new tile.existing flange set on top of old tile.Will i need to raise flange up or can i just cement board and tile up to flange and use two wax rings?
Thanks for the help
trex is offline   Reply With Quote
Old 10-10-2009, 03:15 AM   #2
yes you can use two of the thin wax rings.
fhrace is offline   Reply With Quote
Old 10-10-2009, 09:52 AM   #3
The flange should be "at least" even with the tile top. I would advise using an Flange Extender if it is lower than the tile. they are available in different thicknesses.use the holes in the flange to secure it to the floor. Double wax seals are an option, but often one will slide when installing the toilet and block the drain pipe.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-22-2009, 11:00 PM   #4
Default Flange extender for lead waste pipe
We will soon be installing porcelain tile in an existing bathroom and we'll need to add flange extenders. The original lead waste pipe is formed over the existing brass flange; the house was built in 1959 and this plumbing appears to be original. My local DIY plumbing supplier recommended cutting out this existing flange and replacing with new ABS - not a happy solution as I really don't want to disturb either the tongue in groove fir sub floor or the finished ceiling beneath the bathroom.
Should I fashion and shim around this existing lead to make the flange extender sit on top of this mess evenly or can I trim the lead flush with the flange? If I do trim the flange I’ll likely replace the brass flange with a fresh one. Is there a sleeve I can insert to direct the flow as this lead liner will no longer reach up to the bottom of the toilet?
Sorry for the many scenarios. A photo of the current flange with a temporary 3/8” sub floor in place is attached.
Millrun is offline   Reply With Quote
Old 10-24-2009, 05:32 PM   #5
union journeymem plumber
130 plumber's Avatar
I would have to agree with you except for the wax ring,i would strongly recommend to use plumbers putty to seal your toilet but that just me.
130 plumber is offline   Reply With Quote
Old 10-25-2009, 11:58 AM   #6
Plumbers putty is not made to seal between the toilet and the flange. It is only for touching/compressed surfaces. Toilets have a gap between the bowl and the flange.
Old 10-25-2009, 10:42 PM   #7
well,me and my fellow UA union brothers and sisters use plumbers putty to seal the toilet.Now that being said,i have used wax rings a couple of times cause the customer wanted it and supplied it in the past but i wont give any warranty on a pull and reset with wax rings but i will give a 5 year warranty using plumbers putty
Old 10-25-2009, 11:08 PM   #8
Master Plumber/Mechanical
Never heard of such a thing..plumbers puddy
Now I'm not trying to start something just wondering how does it not dry out or erode?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-26-2009, 07:44 PM   #9
Never heard anyone using plumbers' putty for toilet installation; perhaps it works. Oatey site doesn't mention that use in its description of uses for plumbers' putty. It does mention that use for a wax ring. Next toilet I do, I'll use the wax ring.
bob22 is offline   Reply With Quote
Old 10-27-2009, 10:36 AM   #10
Plumbers putty will shrink slightly and dry out over time. Movement is slight on a properly installed toilet but none the less there will be movement. Once the putty drys and you get a little movement.... You've got a leak. Wax ring is the way to go. Try to get them without the horn. All it does is make you fell better for paying more and restricts the flow.
Rege
p.s. I just noticed the putty guy is a journeyman plumber. Might this be some kind of "initiation" from his fellow Master Plumber UA brothers???
RegeSullivan is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
Cleaning a bathroom that empties into a septic system requires more thought than one that feeds into a city water supply. One does not want to mess up the required bacterium and percentages needed in the septic tank to keep it properly balanced. You do... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Toilet Flange Questions LeviDIY Plumbing 13 06-04-2009 03:22 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 10:07 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 10:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 01:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 11:41 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
