Toilet Flange 3/8" Below Surrounding Tile - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2013, 02:28 PM   #1
Rewards Points: 1,062
Question
Toilet flange 3/8" below surrounding tile
My tile setter had to elevate the tiles around the toilet hole in order to make up for some unevennesses. As a result, the toilet flange is approx. 3/8" below the surrounding tile. Can that be compensated for using extra wax ring or will it even be a problem at all?
Old 04-15-2013, 02:37 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by amakarevic View Post
My tile setter had to elevate the tiles around the toilet hole in order to make up for some unevennesses. Can that be compensated for using extra wax ring or will it even be a problem at all?
Curious: What sort of floor did you have before?
What did your tile setter say about the issue?
Old 04-15-2013, 02:50 PM   #3
I had to sister the beams because they were uneven and in a real bad shape. but you always have imperfections -- I set 3/4" subfloor, then 1/2" plywood, then 1/4" hardibacker. wood frames shift around. he didn't say much
Old 04-15-2013, 03:45 PM   #4
Rewards Points: 528
You will be fine with the extra thick wax ring.
framer52 is offline   Reply With Quote
The Following 2 Users Say Thank You to framer52 For This Useful Post:
amakarevic (04-15-2013), oh'mike (04-16-2013)
Old 04-15-2013, 08:18 PM   #5
Rewards Points: 582
that should have been taken care of ...before tile was finished ,,flange needed to be raised....well as stated double wax or extra thick will work..its certianly is not right....should use a flange extension....ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
amakarevic (04-15-2013), TheEplumber (04-15-2013)
Tags
bathroom , tile , toilet flange
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Toilet flange "too tall" John_W Plumbing 23 04-29-2012 06:20 PM
tile and toilet flange benshouse Plumbing 3 12-29-2010 07:02 PM
someone installed tile over my toilet flange! Emergesunscathe Flooring 3 10-13-2010 02:44 PM
