Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2014, 02:45 PM   #1
Rewards Points: 472
Toilet flange
Iím planning to redo my half bathroom downstairs. I will replace the flooring (hardwood) by tile or vinyl tile
What is the best way to deal with the toilet flange?
I have easy access to the pipe from the basement, so I was thinking it might be easier to completely remove the current one, and cut the pipe underneath
Then once the new flooring is installed, put a new flange and reconnect to the main pipe
About the flange itself, it should be installed over the new floor, right? It doesnít have to be recessed to have the top of the flange flush with the top of the new floor?
french_guy is offline   Reply With Quote
Old 10-02-2014, 03:05 PM   #2
Rewards Points: 472
Toilet flange
I just found this...I guess it answers my question above ?
Correct Flange Placement:
  • The best placement for the toilet flange is with the underside of the flange resting directly on top of the finished floor.
The Following User Says Thank You to french_guy For This Useful Post:
ben's plumbing (10-02-2014)
Old 10-02-2014, 06:47 PM   #3
Plumber/Contractor
TheEplumber's Avatar
Rewards Points: 3,134
Toilet flange
You are correct that the flange elevation should be above the finished floor and there are multiple ways to achieve this.
I like to put a spacer ring of the appropriate thickness under the flange, then screw through both into the sub floor.
You can then cut tile and backer board or underlayment up to the flange and not worry about drilling the tile to anchor the flange.
Here is the one I use- others are available--
http://www.plumbersurplus.com/Prod/S...ftLhoCfw7w_wcB
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 10-02-2014, 07:32 PM   #4
Rewards Points: 654
Toilet flange
you said you have access to underneath....what type of pipe do you have ...if it is castiron..by all means cut it out and install new abs. or pvc flange..if it is plastic follow e plumbers advice...
ben's plumbing is online now   Reply With Quote
Old 10-03-2014, 06:07 AM   #5
Rewards Points: 472
Toilet flange
It's PVC
Old 10-03-2014, 06:11 AM   #6
Rewards Points: 472
Toilet flange
Meaning the spacer ring should be the thickness of the backer board + the tile? They do exist in different thickness?
ben's plumbing (10-03-2014)
Old 10-03-2014, 09:10 AM   #7
Plumber/Contractor
Toilet flange
Yes, or you can stack them.
IMO- the lowest you should have the flange is flush with finished floor and use a jumbo wax.
Old 10-03-2014, 12:54 PM   #8
Rewards Points: 2,452
Toilet flange
To eliminate all guess work cut the pipe below then remove old flange and extend PVC or ABS pipe through the floor. If your pipe is 4 inch once you install floor cut pipe flush and install flange. If your pipe is 3 inch install floor and prior to grouting cut and install flange then grout.
All you need do is drill through the tile with a tap com bit and fasten flange to wood floor with long wood screws or tapcons.
If your also replacing the toilet with new use this instead of wax.
They make a 3 inch and 4 inch version. It will be the last time your toilet leaks.
Ghostmaker is online now   Reply With Quote
Toilet flange question clambake6 Plumbing 18 03-07-2013 10:25 PM
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
