Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2012, 10:56 PM   #1
Rewards Points: 28
toilet flange
I'm tearing up the 1/4 inch lauan and linoleum in a small bathroom. I want to put Harris backer and tile in, do I have to take out the toilet flange (currently an outside of the drain flange) or can I keep it, hardibacker and tile then do an inside drain flange ontop or keep the original flange and use spacers and wax rings to compensate? Thanks in advance!
dmack7 is offline   Reply With Quote
Old 09-10-2012, 11:41 PM   #2
toilet flange
you can leave it. you may need a thicker wax ring when you set the toilet. i used to use 2 thin ones before they made the thicker ones.
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 09:39 PM
