Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2012, 03:57 PM   #31
Originally Posted by oh'mike
For $20 bucks or so you can rent a chain breaker and have that snapped out in 5 minutes--
An angle grinder does a quick job,too---but clearance to cut can be a problem.
Where do you think i could rent one? Do you think HD rents them?
swoop19 is offline   Reply With Quote
Old 02-14-2012, 04:01 PM   #32
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Tired of sawing already?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-14-2012, 05:25 PM   #33
Rewards Points: 616
the best snapper to use is a ridgid 226 but the snap wheels need about 11/4 inches of clearance around pipe then rap around and wrench until it pops will sound like a bag being popped if you do not have the clearance it is messy but take a grinder cut as deep as grinder will go in two spots perpendicular to the pipe with a gap between them large enough to get head of grinder between them then cut parallel to pipe remove that piece then grind rest out from inside of pipe rest of the way around we also use a shop vac with wand by grinder to help with dust i have used abrasive and diamond wheel blades i like the diamond myself
jaydevries is offline   Reply With Quote
Old 02-15-2012, 10:56 AM   #34
DIY staff
Rewards Points: 7,174
Possible---Then we could walk him through 'removing a pipe from a leaded hub'
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 09:39 PM
