Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2012, 10:49 PM   #1
toilet flange
Any advice on how to redo this toilet flange?
It is cast iron and there is no room for a compression type flange without cutting the tile.
I tried a pvc flange with a rubber gasket, but it sat too high and the wax ring got flattened and it still wouldn't sit on the floor
toilet flange-forumrunner_20120211_234925.jpg   toilet flange-forumrunner_20120211_234941.jpg
swoop19 is offline   Reply With Quote
Old 02-11-2012, 11:00 PM   #2
Rewards Points: 13,740
Go under the floor and cut off the pipe, install a hubless connector. Make up a new tail piece out of PVC and a new flange.
Old 02-11-2012, 11:08 PM   #3
Busy DIYer
picflight's Avatar
Rewards Points: 150
What's wrong with the cast iron, why are you replacing it?
picflight is offline   Reply With Quote
Old 02-11-2012, 11:10 PM   #4
No access under the floor. Right now, there is no flange on the cast iron. It was ripped off when the room was demoed.
Old 02-11-2012, 11:45 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That reminds me; I need one of those flanges.
Journeyman Plumber
Old 02-12-2012, 12:01 AM   #6
Here's some ideas on some repair flanges that would work.
http://www.toilet-parts.net/cast-iro...flange-repair/
Old 02-12-2012, 12:11 AM   #7
I've looked at many options and picked 2. The first is the one in my picture and it sits too high to work correctly. The second is too large to fit inside the tile without cutting it to make room. Any ideas?
Old 02-12-2012, 12:16 AM   #8
Rewards Points: 212
What you got will work, but you got to take an angle grinder with a tile blade and cut the tile so that your push on flange will go down further. Or if it is hitting on th cast iron, you are going to have to cut the tile with the tile blade and then switch over to a metal blade and cut the pipe off flush with the floor. That pipe looks like clay to me because it is so thick. If thats the case cut it off with the blade that you cut the tile with. You are just going to have to be very careful that you don't break it. Cut slow and cool it off with water as you cut if it is a clay pipe if you even have to cut it. If you are just hitting on the tile, just cut the tile and leave the pipe alone. You can use a spray bottle to keep the dust down while you are cutting.
bluebird5 is offline   Reply With Quote
Old 02-12-2012, 12:17 AM   #9
A tile bit in a Roto Zip, a diamond blade in a right angle grinder, Ossilating saw with a diamond blade. Take your pick anyone one of them can cut the tile back.
Old 02-12-2012, 12:24 AM   #10
Rewards Points: 212
Joe i don't knlow about that rotozip bit. I have tried them on floor tile and they don't work too well, but they cut through ceramic wall tile ok.
Old 02-12-2012, 12:26 AM   #11
Rewards Points: 212
It looks to me like the pipe itself is too high
Old 02-12-2012, 12:36 AM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 682
That's the thickest cast iron I've ever seen. looks more like clay. Cut it down about an inch and use the inside flange
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (02-12-2012)
Old 02-12-2012, 06:41 AM   #13
DIY staff
Rewards Points: 7,174
Take a file or grinder and clean a spot on that 'cast iron'--I think the Eplumber is onto something--
Clay tile---you may find that an angle grinder with a diamond blade is needed---they are not expensive tools and mighty handy to have around the house.
TheEplumber (02-12-2012)
Old 02-12-2012, 07:36 PM   #14
You guys are probably right about it being clay. I can actually get to if from the basement, but it is a tight squeeze. What would I use to cut it off? Do I use a fernco (hubless connector and then 4" PVC with a new flange on top? If so, I'm guessing I still have to cut the tile opening larger so the flange can sit flush with the finished floor. Is an angle grinder the safest/easiest way to cut that or is there a correct size hole saw for tile that I should use?
Old 02-12-2012, 07:43 PM   #15
Plumber
Rewards Points: 682
i'm not sure where you plan to cut it, I'm actually surprised it's clay Especially in a basement. Clay is usually found outside the foundation and cast iron inside the house. Anyways, there is a fernco called 4"clay x CI/Plastic. It should work at your transition.
plummen (02-12-2012)
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 06:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
