Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2011, 08:56 AM   #1
Toilet flange
Should flange be on top of tile or just subfloor. Thanks
Dano199 is offline   Reply With Quote
Old 10-30-2011, 02:49 PM   #2
Plumb or Die!
Either way works
plumber666 is offline   Reply With Quote
Old 10-30-2011, 02:51 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Toe-may-toe/toe-mah-toe.
Old 10-30-2011, 02:58 PM   #4
Thank you
Old 10-30-2011, 07:30 PM   #5
Rewards Points: 2,512
If you can put flange on top of finshed floor.
See this post for some photos
Toilet Flange Inside or Outside Drain Pipe?
hammerlane is offline   Reply With Quote
Old 10-31-2011, 07:30 AM   #6
Flange should be flush to 1/4" above the finished floor. It can be below, but that requires thicker wax seals and is more prone to leak.
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 09:39 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
