Old 08-01-2007, 04:31 PM   #1
Toilet Flange
Hi, what type of screws and how long would be needed to install a PVC toilet flange to floor? Floor consist of ceramic tile, backerboard, and 3/4 plywood.
Thanks to all.
helpless handyman is offline   Reply With Quote
Old 08-01-2007, 06:54 PM   #2
Union HVAC Tech.
Toilet Flange
#14 x 2 1/4" stainless flathead sheetmetal screws
bigMikeB is offline   Reply With Quote
Old 08-02-2007, 06:46 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Toilet Flange
You also could use Tapcons, too.
For drilling through the tile, tap a starter point with an awl or tape a washer over the drill spot to keep the drill bit from "walking" away when you first start drilling.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-02-2007, 08:41 AM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Toilet Flange
2-1/2" SS square tip heads, drill holes in tile first.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 08-02-2007, 11:08 AM   #5
Toilet Flange
I used 3" SS on mine. It had the aluminum flange though.
Jeekinz is offline   Reply With Quote
Old 08-04-2007, 11:44 PM   #6
Mechanical Contractor
Toilet Flange
A #12 or #14 stainless screw that would be @ 1/4" longer than all you have to penetrate should do just fine.
Ron, why do you prefer the square heads? I just started seeing the combo (square-slotted) heads in my area.
100% Union and proud of it.
MechanicalDVR is offline   Reply With Quote
Old 08-05-2007, 01:19 AM   #7
Journeyman Plumber
Toilet Flange
No reason, there cheaper and stronger then brass screws when securing closet flanges.
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 09:00 AM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
Toilet flange installation Jeekinz Plumbing 1 04-23-2007 05:15 PM
Removing old toilet flange craftycas Plumbing 3 02-22-2005 12:59 PM
toilet flange height Unregistered Plumbing 1 01-27-2004 02:51 PM
