-   -   Toilet Flange (http://www.diychatroom.com/f7/toilet-flange-10350/)
helpless handyman 08-01-2007 04:31 PM
Toilet Flange
Hi, what type of screws and how long would be needed to install a PVC toilet flange to floor? Floor consist of ceramic tile, backerboard, and 3/4 plywood.
Thanks to all.
bigMikeB 08-01-2007 06:54 PM
#14 x 2 1/4" stainless flathead sheetmetal screws
Mike Swearingen 08-02-2007 06:46 AM
You also could use Tapcons, too.
For drilling through the tile, tap a starter point with an awl or tape a washer over the drill spot to keep the drill bit from "walking" away when you first start drilling.
Good Luck!
Mike
Ron The Plumber 08-02-2007 08:41 AM
2-1/2" SS square tip heads, drill holes in tile first.
Jeekinz 08-02-2007 11:08 AM
I used 3" SS on mine. It had the aluminum flange though.
MechanicalDVR 08-04-2007 11:44 PM
A #12 or #14 stainless screw that would be @ 1/4" longer than all you have to penetrate should do just fine.
Ron, why do you prefer the square heads? I just started seeing the combo (square-slotted) heads in my area.
Ron The Plumber 08-05-2007 01:19 AM
No reason, there cheaper and stronger then brass screws when securing closet flanges.
