Toilet Flange 1" Above Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2008, 08:46 PM   #1
Toilet flange 1" above floor
Due to the depth and location of the waste pipe in my basement floor, the toilet I am installing in my powder room is approximately 1" too high (above the floor line). Is there a proper way to fix this? I assume the toilet will not be able to sit on as is. Thanks.
jasoncw is offline   Reply With Quote
Old 03-10-2008, 09:03 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
If the top of closet flange is at 1" above the fish floor. Add 3/4" under the base of toilet with something to raise it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-10-2008, 09:22 PM   #3
Oatey makes white plastic trim plates that are designed to sit underneath a toilet and help cover a multitude of sins in the floor's cosmetics. Perhaps two of those plates glued together will give the toilet the 3/4" lift off of the floor that Ron the Plumber advised. Maybe it's only my personal preference here but I would not use a wood-based product underneath it, especially in a basement where a small flood is always a possibility. Wood may rot from the dampness and smell badly or get moldy.
End Grain is offline   Reply With Quote
Old 03-11-2008, 11:54 AM   #4
Rewards Points: 150
Is shortening the pipe not an option?
kgphoto is offline   Reply With Quote
Old 03-11-2008, 01:50 PM   #5
Not unless you know how to shorten a PVC connection and stay within code. BTW, everything is already glued in, with the exception of the flange.
See pictures here:
Rough-in up to code?
Old 03-11-2008, 03:03 PM   #6
Sounds like it is time to build up the floor to the correct level. It would be a good excuse to have to put radient electric into the bathroom in the thinset. Would probably make the feet happier than standing on cold concrete.
Is there any chance you can shorten the hub and closet flange? Or will the inspector be checking closely?
I set my closet flange over the weekend, on my basement bathroom concrete floor, it stood proud when it was dry fitted, but with the solvent and a little force it seated down inside the pipe.
Greg
Greg_B is offline   Reply With Quote
Old 03-11-2008, 07:00 PM   #7
I'm not going through all that work. I am selling the house, so I just want to get it in and done. I'll most likely just raise the toilet.
Old 03-11-2008, 07:05 PM   #8
25 year carpenter
your best bet is to make a platform 1 inch high or the touh job cut the pipe and refit the flange
osc111 is offline   Reply With Quote
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 08:34 AM
Toilet rocks on tile floor Richo Plumbing 18 11-19-2012 12:04 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 07:58 PM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 09:53 PM
