Toilet Finally Bit The Big One. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2010, 09:19 PM   #1
Rewards Points: 272
Toilet finally bit the big one.
I've known the older ineffiecent toilet in my bath was running on borrow time. Easter morning I walked into my basement and saw water pouring onto the floor. The old toilet finally gave out on me. I was hoping it would last until I decided to remodel my bath. After pulling it and I found soaked and rtten subfloor. Working through easter and today I cut out the old flooring, replaced the old cast iron plumbing and put down a new subfloor. Finally got rid of the 14" toilet
Anyway, I'm looking for a replacement toilet. Looking for an enlongated bowl with a shallow overall depth. 2 piece gravity flush no more than 30 inches depth. Any recommendations. My brother in law swears by Toto but I can't afford a $600 toilet. I'd like to find something under $250.
Anyone own an American Standard Cadet 3? Anything will be better than our old toilet, but I'd like decent flushing power in a realtively compact size.
speedster1 is offline   Reply With Quote
Old 04-06-2010, 06:05 AM   #2
Kohler Wellworth at big box. Not sure of dimensions, but they are for standard connections.
Old 04-06-2010, 08:06 AM   #3
Learning by Doing
Leah Frances's Avatar
Buy a plunger - many homeowners find that when they replace their 'inefficient' or 'high-flow' toilets with a newer model they end up with clogging problems, unless they also replace their older-wider diameter waste pipes.
Good luck, I hate the unwelcome surprise in the morning.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-06-2010, 02:33 PM   #4
Rewards Points: 272
No way I'm keeping the old toilet. It didn't even have a glazed drain.
I'll have a look at the wellworth. And maybe some Jacuzzi styles.
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
