Toilet Filling Slowly. Fast After Twisting Wall Valve. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-29-2011, 02:55 AM   #1
Question
Toilet filling slowly. Fast after twisting wall valve.
First and foremost, thanks for checking this out. More-so if you're able ao help!
After flushing water comes up the fluidmaster and dribbles out of the top veeeeeery slowly and down the arm instead of out the hose into the fill-tube. Is that making sense?
Anyways....
When I twist the cutoff valve coming out of the wall all the way off then back on it will fill normally by going out the hose into the fill-tube. Once filled, if I flush it again, it'll dribble down the arm. The only way I can get it to fill normally is to twist the cutoff valve all the way off and back on each time.
What should I do? What's the culprit? I could pull everything out to do trial and error troubleshooting, but figured I'd ask greater minds to reduces the stress on mine.
100n3y is offline   Reply With Quote
Old 06-29-2011, 07:00 AM   #2
DIY staff
Rewards Points: 7,174
Time for new guts----I suggest that you also consider a new shut of--1/4 turn ball valve----
The guts are cheap---
Old 06-29-2011, 02:54 PM   #3
Thanks for the reply Mike. I understand they're cheap and I guess I'll end up doing that, but for my own curiosity, mechanically, what is it that's causing it to fill normally when I turn the valve off then on again?
Old 06-29-2011, 08:49 PM   #4
DIY staff
Likely the little valve inside is sticking---when the pressure is changed by turning the water off the valve opens.
The new guts are $10 of less and take an experienced person 10 to 12 minutes---You will have to read the instructions so plan in about 30 (unless you are a slow reader)
Old 06-30-2011, 02:28 AM   #5
I'm rockin my reading at, at leeeast, a 1st grade reading level so I better hunker down and get some rations huh? Preciate the help Mike!
Old 06-30-2011, 09:42 AM   #6
Rewards Points: 1,418
Could be something clogging the cutoff valve under the tank, that gets dislodged when you turn that valve.
Old 06-30-2011, 10:07 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Personally I think you might have something stuck in the diaphragm on top of the fluidmaster.
You can remedy this by
1 turning off supply from wall
2 press down and twist (gently) on the top of your fluidmaster while holding the lower portion of it so that it doesnt' twist or snap.
The plastic cap will come off, and you will be able to see if there is debris stuck inside of it.
Pull the rubber diaphragm out, hold your hand over the top of it so as not to make a mess, and turn the supply valve on just a little, to try and flush anything out that may be inside.
Journeyman Plumber
Old 06-30-2011, 10:49 AM   #8
Rewards Points: 1,528
That rubber diaphragm is replaceable as well. Much easier (and pretty much the only wearable part on a Fluidmaster) than replacing all the "guts".
bob22 is offline   Reply With Quote
Old 06-30-2011, 11:16 AM   #9
Lightfoot's Avatar
Rewards Points: 272
i agree
bout 2 bucks.
Lightfoot is offline   Reply With Quote
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
Bathroom - Toilet too close to wall? No vent?! mlenihan Plumbing 5 03-27-2011 08:20 PM
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 11:03 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
