Toilet Fill Valve Spills Water At Top And Emits Bubbles When Near Filled - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2013, 12:23 AM   #1
Rewards Points: 366
Toilet fill valve spills water at top and emits bubbles when near filled
See attached photo of ballcock based fill valve with flapper.
On toilet filling near completion after a flush, I see that the top black part of the fill valve spills water outwards from the center. And at same time the fill valve opening near the bottom emits a series of bubbles before stopping.
I also hear a air hissing sound for a while.
Do all these indicate that the fill valve needs replacing? And why do these things happen together at the fill valve?
Toilet fill valve spills water at top and emits bubbles when near filled-img_20131010_143100.jpg
daluu is offline   Reply With Quote
Old 10-11-2013, 12:27 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
That thing is a dinosaur!
Replace it.
sublime2 is offline   Reply With Quote
Old 10-11-2013, 04:32 AM   #3
Rewards Points: 13,764
Replace it with a new Fluid Master flush valve.
Cost about $10.00 and takes all of 15 min. to replace.
plummen (10-12-2013)
Old 10-11-2013, 07:02 AM   #4
PoleCat's Avatar
Rewards Points: 1,646
The top of that valve can be removed by turning it. There are some rubber parts inside that can be replaced. We used to just flip the washer and get another few years of service out of them.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
daluu (10-11-2013)
Old 10-11-2013, 08:27 AM   #5
Rewards Points: 1,298
It'll get real interesting when that valve breaks off at the base from the pressure put on it from the float. The one I saw happen lifted the lid right off of the tank from the water pressure.
danpik is offline   Reply With Quote
The Following 2 Users Say Thank You to danpik For This Useful Post:
daluu (10-11-2013), plummen (10-12-2013)
Old 10-11-2013, 02:08 PM   #6
Rewards Points: 366
I just noticed the black top part may drip water periodically too. It doesn't do that all the time.
And sometimes I see the tank is not filled to the water line and has hissing air sound, sometimes it is filled to water line, never past it to the overflow though.
Guess it's time to replace. Though I wonder if I should replace with a FluidMaster or traditional ballcock float fill valve. Are the FluidMaster types adjustable in terms of water pressure/fill rate?
My house has some faint water hammer-ish issues (you can hear it but not loud) throughout the water connections in the house (kitchen, bath, etc.). It may be old pipes or not they're not strapped well. That particularly toilet, while the valve is dying, apparently does not result in the water hammer (because it slowly closes the supply or maybe doesn't fully close at all due to current issues). Another toilet that does have a FlushMaster does result in the water hammer noise.
I guess I'll find out when I replace this.
Old 10-11-2013, 02:09 PM   #7
Rewards Points: 366
danpik,
Is that kind of breakage susceptible only to ballcock fill valves and not the single piece FlushMaster type or those can have similar breakage issues too?
Old 10-11-2013, 03:16 PM   #8
That plastic style of ball float valve is a pretty low cost unit. To understand the leverage put on the base, simply lift the float to the top and gently push it higher. You will see the base bend. Over time the constant bending weakens them. Fluidmaster floats keep the pressure even.
Old 10-11-2013, 10:43 PM   #9
Lord of Slums
Rewards Points: 1,974
just replace the whole toilet and be done with it.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
sublime2 (10-12-2013)
Old 10-12-2013, 01:42 PM   #10
Rewards Points: 1,958
Could you get the pressure of your incoming water at a hose bibb?
Old 10-12-2013, 03:37 PM   #11
Rewards Points: 6,652
That is like when someone states they need their oil changed, or spark plugs changed out, to just go buy a brand new car.
The OP just needs to decide what they want to do with that fill valve assembly, and either rebuild or replace with either a Dual flush model, or standard model that looks like the old one.
Old 10-12-2013, 08:51 PM   #12
Lord of Slums
People beat the heck out of themselves trying to save a dollar. I can only afford to do things once. I can get a brand new gerber viper toilet for 80 dollars. I am a cheap landlord and I have found it easier to just replace toilets. The op needs a full rebuild, his seals are toast, judging from the pictures
Old 10-12-2013, 09:12 PM   #13
Really. It only costs around $15 for this kit http://www.acehardware.com/product/i...ductId=1275840 Right there, that saves the OP $65 for a crap crapper.
