Toilet Fill Valve "refluxes" - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2011, 04:49 PM   #1
Toilet fill valve "refluxes"
A few days ago there was a noise coming out of the toilet tank --- the water was coming out at the top of the fill valve. We purchased a new fill valve and installed it. The water/noise stopped for about 5 minutes but unfortunately the water still comes up, almost like a reflux, from the pipe every 2-3 minutes. What can we done to fix this problem.
lison is offline   Reply With Quote
Old 11-03-2011, 06:20 PM   #2
MikeKy55's Avatar
Rewards Points: 254
Sounds like the flapper valve is leaking and the valve needs to refill the tank. Drop some cake coloring in the tank and see if it comes out in the bowl without flushing.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
lison (11-04-2011)
Old 11-04-2011, 09:12 AM   #3
Fill Valve Refluxes
I changed the Flapper and that took care of the problem. Thank you for your tip.
Old 11-04-2011, 11:16 AM   #4
MikeKy55's Avatar
Rewards Points: 254
Glad I could help.
Stop valve has no effect on toilet?? Dannery Plumbing 4 10-11-2011 08:24 AM
Kohler toilet flush valve yarp1 Plumbing 2 04-01-2010 09:59 AM
Toilet Valve eddie3449 Plumbing 6 03-05-2009 03:41 AM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 07:52 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
