Toilet Fiitting Joint - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2010, 08:30 PM   #1
toilet fiitting joint
i had a leak from the toilet pipe. a friend tightened the joint to avoid flooding but he mentioned not to use the restroom because it might flood. what can i do? do i loosen the fitting joint? call a plumber? is there even still a problem with the toilet if it's no longer leaking?
prad is offline   Reply With Quote
Old 02-27-2010, 08:36 PM   #2
Originally Posted by prad View Post
i had a leak from the toilet pipe. a friend tightened the pipe to avoid flooding but he mentioned not to use the restroom because it might flood. what can i do? do i loosen the fitting joint? call a plumber? is there even still a problem with the toilet if it's no longer leaking?
It sounds as if your friend turned off the valve that controls the water.
If you turn on the the valve and water floods out, you will definitely require the services of a plumber!
Old 02-27-2010, 08:43 PM   #3
how do i turn on the valve...turning to the right or left...thank you!!
Old 02-27-2010, 09:20 PM   #4
Turning to the left opens the valve -- I would do it slowly if you think you are going to have a leak
righty tighty -- lefty loosey
meboatermike is offline   Reply With Quote
Old 02-27-2010, 09:29 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
got a picture of the leak?
plummen is offline   Reply With Quote
Old 02-28-2010, 02:28 AM   #6
Lightbulb
thanks everyone. got it done. it's working and not leaking
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
