Toilet Dripping Under Floor. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2011, 06:25 PM   #1
Toilet dripping under floor.
I just installed a Jacuzzi toilet. After flushing it I began to hear rapid dripping under the floor into the drain pipe. I have checked under the floor, no leaks. I put my ear to the pipe. It starts fast and after about five minutes it stops completely. I noticed also after it flushes and refills it drops down just allittle. Flapper is fine. Fill level correct. Fill line into fill tube isn't running. No leaks on floor or under. What else could it be?
ninjaray is offline   Reply With Quote
Old 06-14-2011, 01:28 PM   #2
Any thoughts?
Old 06-14-2011, 01:34 PM   #3
DIY staff
Rewards Points: 7,174
Call the manufacturer---They will have a technical help line.
Sounds like a flaw in the J-bend-----
When tiling a new floor and the floor is unlevel can you still tile it for a toilet? whiz Tiling, ceramics, marble 7 04-22-2010 06:30 PM
Installing toilet on concrete floor diymaniac Plumbing 2 12-14-2009 10:52 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Installing a toilet over harwood floor caglezs Plumbing 5 02-07-2008 11:23 PM
Rotted floor boards. How do I fix THIS??? gshock Building & Construction 4 08-14-2007 06:59 PM
