Toilet Draining - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2012, 01:46 AM   #1
toilet draining
one of two toilets in my house will not flush properly water comes up will not go all way down plunge it one time it will go next time it wont. kitchen and other bath is fine on city sewer not septic tank have taken otu and checked for blockage in toilet itself nothing
tar64 is offline   Reply With Quote
Old 02-05-2012, 08:06 AM   #2
See if all the little holes under the rim are clear. Sometimes hard water can cause calcium build up. A wire coat hanger will do the trick
creeper is offline   Reply With Quote
Old 02-05-2012, 08:19 AM   #3
Rewards Points: 12,886
If that does not work take a look on this site.
http://www.fluidmaster.com/
I like to use a pipe cleaner to clean out those little holes.
You have taken the cover off of the tank and watched what's happening while your flushing, right?
Old 02-05-2012, 03:48 PM   #4
yes have looked everything seems to work right just wont go down
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
toilet draining slowly intermittent ratherbefishing Plumbing 10 01-26-2011 09:57 AM
Slow toilet draining in mobile home Mark Harvey Plumbing 4 04-03-2010 01:39 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
